91 Integra DA with B16a. Speedo cable into guage cluster needed for vtec to work?????????
Do I need the speedo cable to be plugged into the guage cluster for vtec to work? I have the speedo sensor plugged into the tranny, but am going to leave the speedo cable unplugged from the cluster. What do I do?
This is car has a PR3 OBD0 ecu. The tranny is an S1.
yes computer needs to see a speed signal from the instrument cluster, if you dont hook up the speedometer cable the ecu wont see a speed signal and wont engage the the vtec solenoid.
Well, what if I just jumped the vtec solenoid with an rpm activated switch (or window switch)? I have an MSD box. Would that **** the ecu off, such that the ecu set a cel and put it in open loop?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrawow »</TD></TR><TR><TD CLASS="quote">Well, what if I just jumped the vtec solenoid with an rpm activated switch (or window switch)? I have an MSD box. Would that **** the ecu off, such that the ecu set a cel and put it in open loop?</TD></TR></TABLE>
Hacking **** is not gonna make this easier.
HatchBox
Sep 20, 2004 08:32 PM
JohnCRX
Jul 29, 2004 09:00 AM
