DOHC VTEC
Old Feb 3, 2008 | 12:12 PM
GSX 4G63T's Avatar
Default DOHC VTEC
Does it matter if my buddy removes the heat shield?
Old Feb 3, 2008 | 12:13 PM
GSX 4G63T's Avatar
Here's the mileage
Old Feb 3, 2008 | 12:17 PM
GSX 4G63T's Avatar
The car
Old Feb 3, 2008 | 12:36 PM
mrdeadman's Avatar
They let me pick
Default Re: DOHC VTEC (4163175587)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">
Does it matter if my buddy removes the heat shield?</TD></TR></TABLE>
Yes.
And read the rules please.
https://honda-tech.com/zerothread/586924
Old Feb 3, 2008 | 03:59 PM
jhammond_82's Avatar
Reject Papi
Default Re: DOHC VTEC (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">Yes. </TD></TR></TABLE> why? i don't think it would have an adverse affect. i mean, you don't have a heat shield when you install a header do you? if your that concerned about it and are not planning on getting a header you could always take it off and paint it with high temp paint, i've seen it done, it turns out pretty good if its done right.
Old Feb 3, 2008 | 04:01 PM
mrdeadman's Avatar
They let me pick
Default Re: DOHC VTEC (jhammond_82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 &raquo;</TD></TR><TR><TD CLASS="quote"> why? i don't think it would have an adverse affect. i mean, you don't have a heat shield when you install a header do you? if your that concerned about it and are not planning on getting a header you could always take it off and paint it with high temp paint, i've seen it done, it turns out pretty good if its done right. </TD></TR></TABLE>
Underhood temps go up.
Old Feb 3, 2008 | 04:06 PM
Dogginator's Avatar
Daisy... Daisy...
Underhood temps go up. </TD></TR></TABLE>
Not that much. It's a stock cast iron header. Aftermarket SS or mild steel headers with no heat shields will transfer much more heat, resulting in higher underhood temperatures. I really think that the stock heat shield is to conceal the ugly cast iron manifold and protect fingers when checking the oil.
Old Feb 3, 2008 | 04:10 PM
mrdeadman's Avatar
They let me pick
Default Re: DOHC VTEC (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
Not that much. It's a stock cast iron header. Aftermarket SS or mild steel headers with no heat shields will transfer much more heat, resulting in higher underhood temperatures. I really think that the stock heat shield is to conceal the ugly cast iron manifold and protect fingers when checking the oil.</TD></TR></TABLE>
But compared to not having it on there the temps will be higher. Stock versus stock without heat shield, without the heat shield, the temps would be higher.
Old Feb 3, 2008 | 04:14 PM
Reject Papi
Stock versus stock without heat shield, without the heat shield, the temps would be higher. </TD></TR></TABLE>
Aftermarket SS or mild steel headers with no heat shields will transfer much more heat, resulting in higher underhood temperatures.</TD></TR></TABLE>
and like i said, when you install an aftermarket header, you don't reinstall the heat shield. right? an really how much more heat can it produce anyway? i could understand if it was 200 degrees, but its probably more like 20?ish.
Old Feb 3, 2008 | 04:20 PM
mrdeadman's Avatar
They let me pick
The argument was not whether or not he should put a heat shield on an aftermarket header, but whether or not he should take his off a stock header. I say he should not, not only is the stock header ugly as sin, but it would cause the underhood temps to go up, (how much they go up, I couldn't tell you) but when I put my aftermarket header on, without the heat shield, underhood temps where noticeably hotter.
Old Feb 3, 2008 | 04:25 PM
Reject Papi
i do agree that they are ugly, but does the extra heat actually hurt anything? or is it just more of a precaution type of thing? if its precaution i say let him gloat his ugly manifold. if it would hurt something, then i would agree to say no keep it on. but......its his choice i guess.
Old Feb 3, 2008 | 04:38 PM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 &raquo;</TD></TR><TR><TD CLASS="quote">i do agree that they are ugly, but does the extra heat actually hurt anything? or is it just more of a precaution type of thing? if its precaution i say let him gloat his ugly manifold. if it would hurt something, then i would agree to say no keep it on. but......its his choice i guess. </TD></TR></TABLE>
It might not hurt per se, but it doesn't help anything. You want to keep the engine temps as low as possible (but not too low), heat is what destroys stuff.
Old Feb 3, 2008 | 05:11 PM
gibsanez's Avatar
How hot do you honestly think your engine bay gets when you're shoving air into it through the bumper at like 40mph+
Old Feb 3, 2008 | 05:22 PM
WookinPaNub's Avatar
It might not hurt per se, <U>but it doesn't help anything</U>. You want to keep the engine temps as low as possible (but not too low), heat is what destroys stuff. </TD></TR></TABLE>
Weight Reduction!
Old Feb 3, 2008 | 06:05 PM
lowerthanu's Avatar
you should leave the heatshield on, engine bay temp goes up forcing hotter air into your intake decreasing power and increasing wear... aftermarket headers are better suited w/out a heat shield since they're made of higher quality material with power in mind...
Old Feb 3, 2008 | 06:29 PM
Reject Papi
Default Re: DOHC VTEC (lowerthanu)
not with cai it wont.
Old Feb 3, 2008 | 06:39 PM
Blahblah718293's Avatar
theres no reason to do it with a stock header. the weight reduction wont do anything, and the added heat to your engine bay wont make your engine run any better, and will propably dammage the paint on your hood over time.
Old Feb 4, 2008 | 08:15 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 &raquo;</TD></TR><TR><TD CLASS="quote">not with cai it wont. </TD></TR></TABLE>
It will heat up the piping more and thus by induction, heat up the incoming air...
Old Feb 4, 2008 | 09:12 AM
Schister66's Avatar
Man U FTW
It will heat up the piping more and thus by induction, heat up the incoming air...</TD></TR></TABLE>
Dont think that the difference is going to be that great. True, the incoming air is going to be a little hotter than before, but at the same time, a CAI (or any kind of intake piping) is going to heat soak and have the same problem. It wont matter either way. Also, has anyone ever seen the difference in horsepower caused by an intake charge that's say 5*F warmer or colder...?? The difference really isn't that great
Old Feb 4, 2008 | 11:43 AM
gibsanez's Avatar
Default Re: (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">How hot do you honestly think your engine bay gets when you're shoving air into it through the bumper at like 40mph+</TD></TR></TABLE>
Old Feb 4, 2008 | 11:59 AM
Mcdc2's Avatar
I wouldn't take it off because it wouldn't be there for no reason, if it's there it's there for some reason so just tell him to leave it alone unless he plans to get a header.
Old Feb 4, 2008 | 08:05 PM
ZE12O's Avatar
Default Re: (Mcdc2)
i vote, leave it in
take off heat shield only if your installing a new header.
the heat shield is there for a reason, or honda would not have put one there.
plus its extra work to take it off and have ZERO gains out of doing what your doing.
leave it alone, if you have nothing to do, stick in some leds in various places, like all the other cats in the forum hahah.
Kike_Si
Apr 23, 2007 01:25 PM
Robstunner4
Mar 13, 2006 09:39 PM
02spoon
Jun 25, 2005 08:16 PM
93WhiteHatch
Dec 30, 2004 08:25 PM
tegnchewy
Oct 4, 2003 04:39 AM
