BB6 back seat removal
I've got a leak, I assume from the sunroof drain, and my passenger side back seat is soaked, from underneathe. Before i go out there and mess with it, anyone know how, or where to start?
theres a lock on top of the seat, where u insert ur master key and turn to unlock it. that'll take out the top portion of the seat.
for the bottom, u have to feel under the cushion until you feel a plastic piece, just pull the tab out and lift the seat up. there's a total of 2 of those tabs 1 on the left and 1 on the right. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle »</TD></TR><TR><TD CLASS="quote">theres a lock on top of the seat, where u insert ur master key and turn to unlock it. that'll take out the top portion of the seat.</TD></TR></TABLE>
ummm no? you have to pop off 2 little plastic things at the back corners after folding the seatback down. Fold the now free corners of the carpet back and you'll see a bolt on each side. take them out then move the swivel brackets out of the way
THEN you can pull the little tabs to get the bottom part out
stevescivic
10
Feb 27, 2007 06:53 AM
