Radiator Hose? overheating? HELP
Old Feb 3, 2008 | 10:28 AM
kwizical's Avatar
Default Radiator Hose? overheating? HELP
while I was driving my stock 89 crx and it started to overheat. I made it home but right before i got into the drive way I heard a pop and a splshing sound. my temp went down a little bit. and started smoking from under the car (probally coolent). When the car cooled i dumped a whole gallon of coolent into the radiator and heard it leaking from one of the hoses the bypass hose. so my question is did I just blow the hose or is there a bigger problem at hand?
Modified by kwizical at 1:35 PM 2/4/2008
Old Feb 3, 2008 | 10:58 AM
p10hlm's Avatar
Default Re: Radiator Hose? overheating? HELP (kwizical)
sounds like one of your hoses decided to finally let go on you, replace it
and any other hoses that are in need of replacing(the ones that look bloated)
Old Feb 3, 2008 | 02:50 PM
Crx Jimmy's Avatar
it could have broke because there was too much pressure in the system. check the rad cap, you could have busted the headgasket and the cylinder pressure could have popped the hose.
Old Feb 3, 2008 | 07:26 PM
kwizical's Avatar
Default Re: Radiator Hose? overheating? HELP (Crx Jimmy)
it was not the radiator hose that burst. it was the bypass hose right under the dizzy. why would it just burst like that?
Modified by kwizical at 1:33 PM 2/4/2008
Old Feb 3, 2008 | 10:12 PM
DailyDriverCivic's Avatar
I would like to help, but your sentence structure makes it virtually impossible to understand what you are saying. If you can, get someone that speaks english better to type out your problem for you, we could probably help you better. I think it is just an english barrier problem.
chawski
Honda Civic (2001 - 2005)
Jan 1, 2014 02:20 PM
stevej1
Jun 29, 2010 09:17 PM
91EF_Si
Jun 27, 2008 04:38 AM
wannakno
Acura TL, RL & ZDX
Sep 15, 2004 06:48 PM
accorddx
Apr 28, 2004 09:38 PM
