clutch line running into tranny removal?
hey so my motor is swinging in the engine bay from the top two mounts, but the hard clutch line running into the tranny, which looks to be held on by two 12 mm bolts is still attached.
I wanted to know how it comes off/out before I started messing with it? I assume clutch fluid will leak out? Little help please guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.Kelley »</TD></TR><TR><TD CLASS="quote">take the two 12mm bolts out and swing the line out of the way. there should be not fluid lost either
thats wonderful news haha. Thanks
</TD></TR></TABLE>thats wonderful news haha. Thanks
do what R. Kelly said, remove the slave cylinder by removing the two bolts and you will be fine. No brake fluid will come out.
</TD></TR></TABLE>do what R. Kelly said, remove the slave cylinder by removing the two bolts and you will be fine. No brake fluid will come out.
