Camshaft
Old Feb 3, 2008 | 08:00 AM
Nubster's Avatar
Default Camshaft
Does anybody know where i can buy a performance camshaft sprocket for my F23A4 02 Accord? Nobody seems to make that part for my car, ive searched sooo many places.... help!
Old Feb 3, 2008 | 08:18 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Camshaft (Nubster)
lol, no offense but look a bit harder. They are out there. Megan Racing, AEM, Unorthodox Racing to name a few that will most likely make one for your engine. Check out some of the sites listed at the bottom of the FAQ, should be able to find some.
Also, do you have an aftermarket or reground camshaft? If not, there isn't much point in getting an adjustable cam gear (I assume thats what you are looking for).
Old Feb 3, 2008 | 08:33 AM
Nubster's Avatar
Default Re: Camshaft (TouringAccord)
actually... i have the cam GEAR (AEM) but im having trouble finding someone that sells the actual camshaft, the sprocket.... i want to replace the stock sprocket, before i add the cam gear
Do u know where i can find the sprocket?
Old Feb 3, 2008 | 10:07 AM
JGAccorn's Avatar
What is this sprocket you are talking about? You have a cam, and a cam gear. The camshaft itself? Then do like TA said and browse the links. Find a re-grind and slap it in with the AEM gear and you're set. (<simply stated&gt There are tons of manufactures that re-grind honds cams. Look em up. They'll do a custom if you can't find your particular application.
Old Feb 4, 2008 | 03:17 AM
H-T Order of Merit
when someone says sprocket when referring to a camshaft I think the cam gear.
Since you have a cam gear I'll assume you are looking for a camshaft.
I believe Rocket Motorsports regrinds one for the F22B1, try contacting them. Delta also does regrinds for some Accord engines, try contacting them.
blue_egsi
Oct 20, 2012 01:25 PM
Civicman86
Jun 14, 2007 10:33 AM
sohctodohc
11
Jun 5, 2005 07:47 PM
Mr_Bojangles
Apr 15, 2004 06:15 PM
zuzik.2
Sep 3, 2003 07:30 PM
