Team Lovely's H2 Junkyard Civic
So we made a few changes to the car for the upcoming 08 season.
I added rear disc from an Si and bigger fronts from an Accord(Karl just loves that)
We also put in a B16a2 with J4d tranny. I finally got a good alignment and the car got tuned at Carter Racing. So H2 here i come!!!
I would like to thank Johns Honda Recycling for keeping my car on Track last year and for all the help getting it ready again for this year. Karl as always was a big help with the project.
and Karl, youll be seeing alot of this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R »</TD></TR><TR><TD CLASS="quote">
not if my h2 rules request goes through
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokin rubber »</TD></TR><TR><TD CLASS="quote">
not if my h2 rules request goes through</TD></TR></TABLE>
Which one was that? I just found out yesterday that hoods and Lexan are practically a done deal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley »</TD></TR><TR><TD CLASS="quote">
Which one was that? I just found out yesterday that hoods and Lexan are practically a done deal.</TD></TR></TABLE>
Composite hoods are already allowed in H2 no?
Edit: Shane, what's the weight on that thing? Were you able to get it down near the 2250# min weight?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlyZlow »</TD></TR><TR><TD CLASS="quote">Composite hoods are already allowed in H2 no?</TD></TR></TABLE>
No. I thought so too, but they are only listed in the H1 body section and are not in the H1-5 body section or the H2 body section.
Edit: Shane, what's the weight on that thing? Were you able to get it down near the 2250# min weight?</TD></TR></TABLE>
im not sure what the weight is now. i will get weighed this weekend at CMP
im guessin 2300lbs
we will have to take care of that alittle later. just about all the sound det is in still along with lots of extra wiring including the dome light that still works
i need to get out there right now
im guessin 2300lbs
No. I thought so too, but they are only listed in the H1 body section and are not in the H1-5 body section or the H2 body section.</TD></TR></TABLE>
10.2(m) on page 14 or 16 covers it for LPVs, or are you referring to RPVs?
I could have sworn that I had read that hoods were already allowed, so I went and found it.
Under section 10.2 - H2 Limited Prep Rules
m) Non OEM composite hoods are permitted
117 was right on with the section number.
I think the rules request that's outstanding may be for allowing composite trunks and hatches as well as lexan rear windows.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">It would only make since the hoods, trunks, and lexan are allowed in H2</TD></TR></TABLE>
hoods are, currantly lexan and trunks/hatches are not.
Not so. Hoods only so far.
Not so. Hoods only so far.</TD></TR></TABLE>
My statment was in regards to <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley »</TD></TR><TR><TD CLASS="quote">
And that it only makes sense to let all of them in.
single cam f22/23 in H2 details are in the works
single cam f22/23 in H2 details are in the works</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucid Moments »</TD></TR><TR><TD CLASS="quote">Sweet...with Shane and Karl in H2 I will be winning every HC H4 race...unless I dont finish!
Matthew</TD></TR></TABLE>
.....maybe not.
Scott
.....maybe not.
Scott
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aahj »</TD></TR><TR><TD CLASS="quote">what accord brakes are you using? Rotors?
Just curious.
Looks good! Good luck this season!
Aahj</TD></TR></TABLE>
He has 92-97 accord calipers and brackets, they are almost the same as the 99-00si and some other civics, the difference is the accord calipers fit a thicker pad. He is using them with civic ex/si integra rotors.
Just curious.
