easy do it yourself way to turn off maintenance light?
Old Feb 2, 2008 | 10:11 PM
chatman_55's Avatar
Default easy do it yourself way to turn off maintenance light?
maintenance light is on for bs reason is there a way i can shut it off myself?
Old Feb 2, 2008 | 10:14 PM
nate_2k5's Avatar
Default Re: easy do it yourself way to turn off maintenance light? (chatman_55)
theres a button right about where your right knee hits the dash that you have to press in when the car is at ACC, like it says in the owners manual
posHonda's Avatar
turn the key to the ON position where the gauge cluster lights up. theres a button under the dash a bit to your right probably close to where your knee would be. hold it and itll turn off.
the maintenance reqd light is just a reminder to do your maintenance.
Old Feb 2, 2008 | 10:42 PM
Steven.'s Avatar
Default Re: (posHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by posHonda &raquo;</TD></TR><TR><TD CLASS="quote">turn the key to the ON position where the gauge cluster lights up. theres a button under the dash a bit to your right probably close to where your knee would be. hold it and itll turn off.
the maintenance reqd light is just a reminder to do your maintenance.</TD></TR></TABLE>
Its a reminder to pay honda/acura some money because they want some pocket change
Old Feb 3, 2008 | 01:28 AM
jhammond_82's Avatar
Reject Papi
Default Re: (Steven.)
why not just fix the problem and make it go off.
Old Feb 3, 2008 | 01:55 AM
bpkmrtoes's Avatar
Default Re: (jhammond_82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 &raquo;</TD></TR><TR><TD CLASS="quote">why not just fix the problem and make it go off. </TD></TR></TABLE>
because it is a maintenance light... light that comes one when you need maintenance... like oil changes... that people usually do on their own...
Old Feb 3, 2008 | 09:08 AM
nate_2k5's Avatar
Default Re: (bpkmrtoes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes &raquo;</TD></TR><TR><TD CLASS="quote">
because it is a maintenance light... light that comes one when you need maintenance... like oil changes... that people usually do on their own...</TD></TR></TABLE>
no its usually more serious maintenance like water pump etc
Old Feb 3, 2008 | 09:13 AM
all-mtr-teg's Avatar
Default Re: (nate_2k5)
Yeah it usually comes on after like every 25-40k miles for more of the major maintenance like timing belt, transmission fluid, etc.
Old Feb 3, 2008 | 10:38 AM
chatman_55's Avatar
Default Re: (all-mtr-teg)
I know there is nothing that needs to be done to the car the mechanic that worked on it last was too stupid to shut off the light when done, and i didn't want to take it back to them just to have it turned off, it is off now thanks for the help.
Old Feb 3, 2008 | 10:42 AM
Brice.Hayden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Yeah it usually comes on after like every 25-40k miles for more of the major maintenance like timing belt, transmission fluid, etc.</TD></TR></TABLE>
umm no..mine comes on every 5000k miles when its supposed to. It's your reminder to change your oil.
Old Feb 3, 2008 | 10:54 AM
chatman_55's Avatar
Default Re: (Brice.Hayden)
i just had my oil changed.
Old Feb 3, 2008 | 11:07 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brice.Hayden &raquo;</TD></TR><TR><TD CLASS="quote">
umm no..mine comes on every 5000k miles when its supposed to. It's your reminder to change your oil. </TD></TR></TABLE>
You mean 5k miles, and no mine doesn't come on that often, maybe because i never go past 4k miles in between oil changes, so far mines only come on at 40K and 80k miles. I believe if it glows yellow that's an indicator to perform a scheduled maintenance, it it glows red you've gone over the scheduled maintenance by a certain mileage.
Old Feb 3, 2008 | 12:30 PM
mrdeadman's Avatar
They let me pick
Mine comes on every 7500 miles. Oil change reminder... I don't know where you people are getting all this bullshit.
Old Feb 3, 2008 | 02:09 PM
WookinPaNub's Avatar
Default Re: (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">Mine comes on every 7500 miles. Oil change reminder... I don't know where you people are getting all this bullshit. </TD></TR></TABLE>
Owner's manual says between 6000 and 7500 miles and it is just a reminder. It will come on no matter what.
Old Feb 3, 2008 | 04:24 PM
Steven.'s Avatar
Default Re: (WookinPaNub)
Cut the wire that turns it on.
Old Feb 3, 2008 | 04:28 PM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven. &raquo;</TD></TR><TR><TD CLASS="quote">Cut the wire that turns it on.</TD></TR></TABLE>
Cutting any OEM wire is generally a bad idea. That is how people end up with hacked up wiring harnesses and looms that look like a rat's nest.
Old Feb 3, 2008 | 04:30 PM
Really, cause i have 2 gsr's and the maintenance lights never come on that often. Like I said, i never go over 4k miles in between oil changes.
Old Feb 3, 2008 | 04:34 PM
BryanM.'s Avatar
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_2k5 &raquo;</TD></TR><TR><TD CLASS="quote">
no its usually more serious maintenance like water pump etc</TD></TR></TABLE>
okthanxbye
That light has NO idea if the water pump needs replacing.
It's the "Oh no's! The light turned RED!!! I'm goin' to the dealership" light.
Old Feb 3, 2008 | 04:35 PM
mrdeadman's Avatar
They let me pick
Really, cause i have 2 gsr's and the maintenance lights never come on that often. Like I said, i never go over 4k miles in between oil changes.</TD></TR></TABLE>
It is Honda recommended to change the oil every 7500 miles, because most people don't drive their cars except to commute... Are you sure your light doesn't come on every 7500 miles?
Old Feb 3, 2008 | 04:42 PM
Im sure they don't come on that often cause i am constantly checking my temps, oil pressure, mileage, etc.
And I change my oil every 4k miles cause I drive my cars like they are stolen If I babied my cars and didn't drive through dusty country roads then yeah maybe I would go 7500 miles between oil changes.
Old Feb 3, 2008 | 04:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Im sure they don't come on that often cause i am constantly checking my temps, oil pressure, mileage, etc.
And I change my oil every 4k miles cause I drive my cars like they are stolen If I babied my cars and didn't drive through dusty country roads then yeah maybe I would go 7500 miles between oil changes.</TD></TR></TABLE>
It doesnt matter how often you change your oil. You could change it every day and it still should come on between 6000 and 7500 miles. (Read your owners manual.) Where's Dogg for some legit information?
Old Feb 3, 2008 | 06:08 PM
Steven.'s Avatar
Get the wiring diagram and cut the correct wire, its just a timed light just like an alarm clock with a primitive concept.
Old Feb 3, 2008 | 06:36 PM
nate_2k5's Avatar
Default Re: (mcvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec &raquo;</TD></TR><TR><TD CLASS="quote">
okthanxbye
It's the "Oh no's! The light turned RED!!! I'm goin' to the dealership" light.</TD></TR></TABLE>
i never said it sensed it, but it comes on at the ~90k interval, its an interval based light not sensor based
Old Feb 4, 2008 | 08:18 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WookinPaNub &raquo;</TD></TR><TR><TD CLASS="quote">
It doesnt matter how often you change your oil. You could change it every day and it still should come on between 6000 and 7500 miles. (Read your owners manual.) Where's Dogg for some legit information? </TD></TR></TABLE>
I just gave everyone the legit information and so did you.
i never said it sensed it, but it comes on at the ~90k interval, its an interval based light not sensor based</TD></TR></TABLE>
Yeah, and it comes on every 7500 miles or so to remind you change your oil. That is all, nothing more.
Stop posting all this bullshit. Read your owner's manuals.
Old Feb 4, 2008 | 08:47 AM
Berlinetta F1's Avatar
0-4000 miles - stays on for two seconds
4000-6000 miles - flashes ten times, then turns off
6000 miles+ - stays on indefinitely
the mileage may not be perfectly presice. but I am pretty sure thats how it works.
Its really nothing more than a timer to tell you when you need to change your oil. its not some magical sensor that can tell theres new oil in the system. YOU have to reset it, unless you take your car to a honda/Acura dealer to change your oil, in which case THEY will most likley reset it for you. as for reseting the light, there is a button located under the driver side dash, on the right side of the stering wheel, turn the ignition to ACC on, push and hold the button till the maintenance light flashes and then turns off "problem" solved
