please help i really need it
Old Feb 2, 2008 | 06:31 PM
northemt88's Avatar
Default please help i really need it
so i have a 1991 civic withe a b18a1 block and b18b head,it was int holding idle at first so i replaced the iacv and the one under the throttle body that didnt fix it.it turns out it was the wires for the iavc.now it starts on its own it idles from 2000 to 300.when i drive its okay but when i let off the gas it feathers down super slow.ill down shift and its like im giving it gas please help i need it
Old Feb 2, 2008 | 06:46 PM
one-cam's Avatar
Default Re: please help i really need it (northemt88)
the gas linkage on ur throttle body might be over tightened when u changed the iavc.. idk if u took it off or not but when i took mine off i messed with the whole manifold
Old Feb 2, 2008 | 07:26 PM
Cvic90's Avatar
you may have a vacuum leak on the fast idle valve you replaced. Or the throttle body, did you replace the gasket?
DeLSoLRo
20
Apr 23, 2011 10:06 AM
b18b1ef8
Aug 7, 2008 10:03 AM
crx18c1
Feb 12, 2007 03:14 PM
