2001 Accord doesn't always start
Old Feb 2, 2008 | 02:12 PM
beckysrij's Avatar
Default 2001 Accord doesn't always start
For the past 2 months I've had a problem with my 2001 Accord not always starting. When I turn the key, it makes a "woo woo woo" sound (but no clicks) and after 5 to 10 tries it will finally start. It doesn't happen every time I start the car and it will be fine for a few days or up to a week but then it will happen again. Sometimes pressing the gas pedal helps and at other times it doesn't make any difference. Has anyone had this problem and/or have an idea what's wrong?
Old Feb 3, 2008 | 06:22 AM
turbo graphix 16's Avatar
Default Re: 2001 Accord doesn't always start (beckysrij)
Any CEL's on? I kinda had the same prob, but giving gas wouldnt help mine and i had a CEL on... after fixing the CEL and it was still doing it i found out it was the ignition lock cylinder.
Also is your maintence up to date? Fuel filter could cause that too.
Old Feb 3, 2008 | 07:15 AM
The-Kid's Avatar
Default Re: 2001 Accord doesn't always start (turbo graphix 16)
How is your battery? I'm guessing your starter.... Because you did said it works fine in the other days. BTW are you starting this in cold weather? It could be also a semi weak battery. Does your car take 3 turns before starting the car or 2?
98+ Accords do not have a fuel filter. They have like a mesh type "sock filter" in the fuel tank that is unserviceable.
KYRGYZ
Aug 17, 2017 09:14 AM
acidburn2k2
Mar 10, 2017 08:58 PM
tshark21
Jul 17, 2010 10:16 AM
reeder5001
Jan 15, 2010 05:26 PM
kicker1_solo
Apr 25, 2008 09:26 PM
