f22b1 what flywheels fit?
iam building a f2d adapter plate and the engine was a auto so i need a flywheel for it and i found a f22a4 at the junkyard and i dont know if it will fit and dont want to go and pull the flywheel if it wont fit.
iam going to the junkyard in jacksonville soon and need to know what cars have the same bolt patteren years and models stuff.
thanks
thanks
All 90-97 F22 flywheels are the same size.
I'm pretty sure I read a thread on here talking about doing the H2D swap and sticking with the lighter smaller D series clutch and flywheel.
Here is a link to an H2D build;
https://honda-tech.com/zerothread/1749840
The D series flywheel is approx 11" and the F is 12". It might be a bit of a squeeze for it to fit inside the d tranny. Hit up Bisimoto and see if he will tell you what diameter the flywheel is that is used in his H2D kit.
ok thanks people
i have read up on everything i can about the h/f2d adapter they dont like to give information away from the company
i have fig away to install the tranny to the block and make room for the balancer without any custom cutting thanks to some old guy i know and work for
f22 is f22 on flywhell same from 90 thru 97 i used me flywheel off my motor on my swap , ihave a 90 ex accord and put a 97 f22b1 in it works perfect....
meltSolid
Dec 3, 2002 11:33 PM
