code 1 and 7
code #1 is your Oxygen Sensor "A
code # 7 TP Sensor (Throttle Position) TPS
code #10 IAT Sensor (Intake Air Temperature)
code # 20 Electrical Load Detector
a lot of people get the code 1 and 10 mixed up...
honda codes
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
85-89 86-87 n/a 85-87 85-91 n/a n/a Oxygen Sensor "B"
85-98 86-98 97-98 85-91 93-97 95-98 85-98 MAP Sensor (Manifold Absolute Pressure)
90-98 88-98 97-98 88-91 93-97 95-98 85-98 CKP Sensor (Crankshaft Position Sensor)
85-98 * 86-98 97-98 85-91 93-97 96-98 85-98 MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
* exc 94-95
85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature)
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TP Sensor (Throttle Position)
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TDC Sensor (Top Dead Center)
9*
85-98** 86-98 97-98 85-91 93-97 95-98 85-98 CYP Sensor (Cylinder)
* not a valid code for any throttle body injection Hondas
** not a valid code for V-6 engines
10
85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature)
12
85-98 86-98 * n/a 85-91 * n/a 95-98 85-98 EGR Lift Sensor (Exhaust Gas Recirculation)
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
13
85-98 86-98 97-98 85-91 93-97 95-98 85-98 BARO Sensor (Atmospheric Pressure)
14
88-98 88-98 97-98 88-91 93-97 95-98 88-98 IAC Valve (Idle Air Control)
15
90-95 88-95 n/a 88-91 93-95 95 88-95 Ignition Output Signal
missing or defective ignition output signal
16
90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System
defective circuit or unplugged / defective fuel injector
17
88-98 88-98 97-98 88-91 93-97 95-97 88-98 VSS (Vehicle Speed Sensor)
19
n/a 88-95 n/a 88-91 93-97 n/a n/a Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20
90-98 88-98 97-98 88-91 93-97 95-98 92-98 Electrical Load Detector
21*
94-98 ** 92-95 n/a n/a 93-95 n/a 93-95 VTEC Solenoid Valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
22*
94-98 92-98 n/a n/a 93-97 98 93-98` VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23
98 * 96-98 n/a n/a 94-97 n/a 92-98 KS (Knock Sensor)
* not a valid code if V-6 engine
30
90-98 * n/a n/a n/a n/a 95 92-98 * Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
* not a valid code for 1996
31
90-95 n/a n/a n/a n/a 95 92-95 Automatic Transmission Signal "B"
41
90-98 92-98 97-98 n/a 93-97 95-98 90-98 Primary Oxygen Sensor - Heater
circuit malfunction
43
90-95 92-95 n/a n/a 93-95 95 90-95 Fuel Supply System
defective or malfunctioning fuel supply system
45
96-98 96-98 97-98 n/a 96-97 96-98 96-98 System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48
98 92-98 n/a n/a n/a n/a n/a LAF Sensor (Lean Air Fuel)
54
96 96-98 97-98 n/a 96-97 n/a n/a CKF Sensor (Crankshaft Speed Fluctuation)
58
98 * n/a n/a n/a n/a n/a n/a TDC Sensor 2 (Top Dead Center)
* with V-6 engine only
61
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 2 (Secondary)
65
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70
96-98 96-98 97-98 n/a n/a 96-98 96-98 Automatic Transmission
malfunction with the automatic transmission controls
71
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 2 Misfire or a Random Misfire
73
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 3 Misfire or a Random Misfire
74
96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 4 Misfire or a Random Misfire
75
98 * n/a n/a n/a n/a n/a n/a Cylinder 5 Misfire or a Random Misfire
* valid code for V-6 engine only
76
98 * n/a n/a n/a n/a n/a n/a Cylinder 6 Misfire or a Random Misfire
80
96-98 96-98 n/a n/a n/a 96-98 96-98 Exhaust Gas Recirculation
insufficient flow detected
86
96-98 96-98 97-98 n/a 96-97 96-98 96-98 ECT Sensor (Engine Coolant Temperature)
circuit range / performance problem
90
97-98 96-98 n/a n/a n/a 98 97-98 Evaporative Emission Control System
leak detected in the fuel tank area
91
96-98 96-98 n/a n/a n/a 98 97-98 Fuel Tank Pressure Sensor
low input
92
96-98 96-98 97-98 n/a 96-97 96-97 96-98 Evaporative Emission Control System
honda codes
* exc 94-95
9*
10
12
13
14
15
16
17
19
20
21*
22*
23
30
31
41
circuit malfunction
43
45
48
54
58
61
63
65
67
70
71
72
73
74
75
76
80
86
90
91
low input
92
jenishereto
Mar 7, 2014 04:16 AM
slammedz6ef
Feb 2, 2008 10:30 PM
endlesswinterco
Jan 7, 2004 01:40 PM
bubbajim
Apr 5, 2003 08:19 AM
