want to change to power windows
if u want real honda power windows ur gonna need to buy the switchs either from this site or maybe from ebay >< good ones will run you 150+ i would say. if u want just any switchs you can have the show put them in by the sunroof switch or maybe somewhere else, i had some general switchs put in the center console so both people could reach the switchs. also if u want the honda ones ull need some SiR door panels, and most of them are right hand drive so the switches will be on the opposite sides looks sorta gay
the real question first is, do u want just any power windows or do u want oem/jdm power windows. answer that then we can get started
The best thing to do IMO, is to buy JDM window motor/regulator assemblies. Then go to the SPAL website and get some aftermarket switches. Then wire them up yourself. I put some JDM Hatch regulators in a friends 90 si and then I found some ford contour power window switches and I wired it up and mounted the swithes in the center console. It look clean and worked great. He made his own covers for the door panel holes. the contour switches are backlit and didn't require relays. It made the install easier to wire.
fenix4o9
Jul 10, 2007 04:07 PM
EKCRX-Ihadastupidusername
13
Nov 22, 2005 08:43 PM
95excoupe
Mar 9, 2003 12:04 AM
