Suspension & Brakes Theory, alignment, spring rates....
Removing front LCA/Suspension parts on EG
Old Feb 1, 2008 | 09:21 PM
Morasso's Avatar
Default Removing front LCA/Suspension parts on EG
So I got in a bit of a wreck today and expletiveed up my front drivers side suspension:
Obviously my wheel is a littler farther back than it should be.
I'm guessing my front LCA is bent, but i'm wondering what else is possible messed up. I plan on going to the junkyard tomorrow and picking up some parts, but i'm not exactly sure what to get.
I'm sure i need to get a new LCA, but what else? Also, how difficult is it to remove the suspension peices? Can I remove the LCA and stuff like that WITHOUT removing the axle?
Thanks guys!
Old Feb 2, 2008 | 08:56 AM
crazykamper's Avatar
recently did similar... on crx though, you can remove the lower control arm without removing the axel... just remove if from the subframe/fork/and the knuckle... its pretty basic stuff...
when ya get the new stuff i would inspect all the rest... the strut/fork may have bent a lil bit... if so, then it will be bouncy in that corner... good luck! hopet thats all the got messed up!
Dipsett
Suspension & Brakes
10
May 6, 2013 10:49 AM
DC2-ProdUcTiOnS
13
Sep 22, 2009 08:49 AM
BenMasters2
May 9, 2006 06:40 PM
Ratchback
Nov 12, 2005 01:17 PM
gojo0401
May 19, 2004 07:08 AM
