oil out the dipstick base
Old Feb 1, 2008 | 08:12 PM
mitsuman's Avatar
Default oil out the dipstick base
so my oil dip stick base is leaking slowly. will leak even at idle. there is an oring there right? but would it leak even at idle? just seems weird
yes i have a catch can set up that i need to upgrade. i have the 2 ports on the back of the block and one coming off the valve cover
Old Feb 1, 2008 | 08:59 PM
kyden's Avatar
Default Re: oil out the dipstick base (mitsuman)
i don't believe there's an o-ring. its just push fit.
Old Feb 1, 2008 | 09:26 PM
mitsuman's Avatar
Default Re: oil out the dipstick base (kyden)
any body have a picture of what it should look like, mine seems to be slightly raised off where it fits the block.
Old Feb 2, 2008 | 08:42 AM
SOHC_MShue's Avatar
There is an oring at the bottom if i remember correctly.
Old Feb 2, 2008 | 10:31 AM
melovesboost's Avatar
Default Re: oil out the dipstick base (SOHC_MShue)
On the Honda Site for parts doesnt look like there is a Oring and there is not one listed as a part. looks like its just pressed fit
Old Feb 2, 2008 | 10:34 AM
Tchleung's Avatar
Every one I've pulled out has no O-Ring, I beleive on some of the older accords etc you were able to remove them as they were held in by a 6mm bolt so in those cases, there was an o-ring. But on all B-series, it should be a press fit with a tight tolerance to seal it as it should only be oil splashing on it. Best thing to do is pull it out, clean it up, jbweld it back in or silicone it in.
Old Feb 2, 2008 | 11:52 AM
SOHC_MShue's Avatar
hmm maybe i was wrong about the oring. i thought for some reason my old y8 motor had one.
Old Feb 2, 2008 | 12:45 PM
97grnrs's Avatar
pinch the top of the tube a lil so it stays tighter .
Old Feb 2, 2008 | 01:40 PM
Tippyman's Avatar
Default Re: oil out the dipstick base (97grnrs)
HOndabond
Old Feb 2, 2008 | 02:12 PM
Tchleung's Avatar
That is correct, your Y8 did have the removable dipstick tube which was sealed with an O-Ring. But as you see, there is a sorta clamp/bracket that holds it down that you take off as well. most dipstick tubes that ahve a bracket of some sort, are removable, unlike all b-series
Old Feb 2, 2008 | 05:12 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">pinch the top of the tube a lil so it stays tighter . </TD></TR></TABLE>
If the dipstick was coming out maybe, but he said the tube at the base of the block.
Old Feb 4, 2008 | 11:49 PM
mitsuman's Avatar
Default Re: oil out the dipstick base (nsxmatt)
ok so i had a chance to really look at it today, its not coming out the dip stick thing. its a small crack in the block above the dipstick area in one of those galleys. so i j-b welded it and its not leaking now. although it does have me concerned.
Old Feb 5, 2008 | 09:02 AM
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitsuman &raquo;</TD></TR><TR><TD CLASS="quote">ok so i had a chance to really look at it today, its not coming out the dip stick thing. its a small crack in the block above the dipstick area in one of those galleys. so i j-b welded it and its not leaking now. although it does have me concerned. </TD></TR></TABLE>
thats wierd, but guess not to wierd considering there is a technical repair bulletin honda put out a while back for the accords where the block casting was too pourus and seeped oil and the fix for it was to JB weld the area...
Old Feb 5, 2008 | 09:13 AM
mitsuman's Avatar
Default Re: oil out the dipstick base (agrn93ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls &raquo;</TD></TR><TR><TD CLASS="quote">
thats wierd, but guess not to wierd considering there is a technical repair bulletin honda put out a while back for the accords where the block casting was too pourus and seeped oil and the fix for it was to JB weld the area...</TD></TR></TABLE>
interesting. was weird because i looked for a crack but didnt see anything, all i saw were 2 tiny pin holes that i wasnt sure if they were holes or just indents. o well
SisterFister
Jan 29, 2010 04:09 PM
Civichatch27
Jan 3, 2005 04:56 PM
2000Accord5sp
Sep 17, 2002 04:17 PM
Canuk_SiR
May 19, 2002 06:30 PM
