«-- MLBZ521's For Sale Thread --» Prelude Engine, Exterior, Interior, & Other Parts!
Old Feb 1, 2008 | 02:12 PM
MLBZ521's Avatar
Icon5 «-- MLBZ521's For Sale Thread --» Prelude Engine, Exterior, Interior, & Other Parts!
In the next few days, hopefully by the weekend, I'm going to go through all what I have let and post up everything that I don't have listed.
I moved in case you didn't notice.
Car was STOLEN AGAIN and Stripped this time. So everything I have is For Sale!
[Updates: (8/28/10) Added some new pictures and a couple parts.
(11/10
/09) Added MORE New Pictures.
(8/10
/09) Car was located. Everything up for sale.
(8/7
/09) Car stolen again.
(1/22
/09) CAR LOCATED! Updated post.
(1/17
/09) Added MORE Parts!
(1/10/09) Well, my car was stolen while I was out of town over the Holiday's.
(11/16/08) Added New Parts!]
Shell no longer available.
FS/FT - '94 Prelude Si - JDM H22A Swap, Built Trans + Tastefully Modified
Since my car was stolen, again, and stripped this time, I'm selling everything I have collected. If there is something you need, but it's not listed, just message me and I'll see if I do. I'm always finding and adding stuff to the list, so check back often. If pictures aren't listed for an item, E-Mail or Message me and I'll be happy to take some. Everything here is Best Offer! Check my profile for ways to contact me, I'm easy to reach.
Thanks for looking!
Collectibles
1994 Honda Prelude Brochure - All the Specs of the 1994 Prelude, Cover Shows Wear, Pages are in Great Condition!
SOLD --» Mugen Prelude 5thGen Poster
SOLD --» GP Super All Japan Drift Model
SOLD --» Jun Model
Engines and Transmissions
SOLD --» Fully Built All Motor H22A4 Short Block w/ Fully Built H22A1 Cylinder Head by RS Machine - Info in For Sale Thread
SOLD --» JDM H22A P&P Cyl. Head & P&P IM w/ TB
SOLD --» JDM M2B4 LSD Transmission x 2
SOLD --» Cracked Case H22 Transmission
SOLD --» Damaged M2S4 Transmission
SOLD --» H22A4 VTEC Cylinder Head
SOLD --» JDM H22A Short Block
Brand New
Genuine Honda Parts:
SOLD --» Valve Cover Gasket - Brand New, H22
(Can't Find, I think I used them.) Flywheel Bolts 12mm x 1 Set, Part Number #90011-PH3-000 - For H-Series
(Can't Find, I think I used them.) Belt Part Number #38920-PT0-004, #5PK1065 - Used for 500 Miles. - Belt 1 | Belt 2
SOLD --» Cam Plate 12MM bolts, 20 pcs, Part Number #95701-0805008
SOLD --» Cam Plate 10MM bolts, 8 pcs, Part Number #90002-PJ7-010
SOLD --» Clutch Fork - For H-Series
Clutch Slave Cylinder - Bleeder Bolt Broke, needs to be removed.
SOLD --» SMSP 2.5" Exhaust Tubing Kit & Cat
SOLD --» Powered Coated H22 VC & SPC
SOLD --» C&R Visteon Half-Size Radiator
SOLD --» Magnaflow Resonator #10436
SOLD --» JUN H22 UltraLight Flywheel
SOLD --» Skunk2 Stage 1 Camshafts
SOLD --» XTD ProLite 12lbs Flywheel
SOLD --» AEBS Head Studs & Socket
SOLD --» Skunk2 Rear Lower Tie Bar
SOLD --» Power Guard Battery Case
SOLD --» 4thGen Prelude Car Cover
SOLD --» Unorthodox Crank Pulley
SOLD --» Civic Half Sized Radiator
SOLD --» Euro R Spec Camshafts
SOLD --» Spoon Radiator Bracket
SOLD --» XTD Stage 3 Clutch Kit
SOLD --» AEM Accessory Pulleys
SOLD --» H22 OBD1 Distributor
SOLD --» AEM Fuel Regulator
SOLD --» GReddy Timing Belt
SOLD --» Skunk2 Cam Gears
SOLD --» SMSP H22 Header
SOLD --» AEM Fuel Rail x 2
Stock JDM Prelude/H22A Parts - All the following are USED.
JDM Corner Light Harness - I've completely "rebuilt" this harness, better than new! - Before 1 | Before 2 | Before 3 | Before 4 | Before 5 | During 1 | During 2 | After 1 | After 2 | After 3
JDM Front Bumper - 4thGen, Silver, Very Good Condition, Has Lip on it and Red Acura Badge (???)
JDM Fog Light Switch - Has Pigtail
SOLD --» JDM Digital Climate Control - 5thGen Complete Setup (Could probably source another 4th or 5thGen Setup)
JDM Inside Side Mirror Covers - Cover 1 | Cover 2 | Cover 3 | Cover 4
JDM Side Mirrors (Just the Mirrors Themselves) - 4thGen
JDM Black Box from below the Intake Manifold (Solenoid box for IAB) - Box 1 | Box 2
JDM Auto Tensioner (Multiple Parts) - Parts
JDM ALT Bracket - Bracket 1 | Bracket 2
JDM AC Bracket
JDM Timing & Balancer Belt Gears
JDM Head Studs
JDM Balancer Belt
Any Misc. Bracket/Bolt/Gasket/Seal, I probably have it..
Cut JDM H22A Engine Wiring Harness for whole or as parts (Plugs).
SOLD --» Injector Plugs, Map Sensor Plug, & 1 x Green Two-Wire Plug
SOLD --» JDM Digital Climate Control for 4thGen x 2
SOLD --» JDM Cornering & Amber Signal Lights
SOLD --» JDM Stripped H22A Intake Manifold
SOLD --» JDM H22A Injectors 345cc x 2 Sets
SOLD --» JDM H22A Intake Manifold w/ TB
SOLD --» JDM H22A VTEC Camshafts
SOLD --» JDM Clutch Slave Cylinder
SOLD --» JDM Thermostat Housing
SOLD --» JDM Distributor TD-60U
SOLD --» JDM H22 Timing Covers
SOLD --» JDM Fuel Regulator x 2
SOLD --» JDM Side Mirror Covers
SOLD --» JDM AC Compressor
SOLD --» JDM PS Bracket x 2
SOLD --» JDM P13 H22A ECU
SOLD --» JDM M2B4 Starter
SOLD --» JDM Fuel Rail x 2
SOLD --» JDM Door Panels
SOLD --» JDM Cam Gears
SOLD --» JDM AC Bracket
SOLD --» JDM Fog Lights
SOLD --» JDM Headlights
SOLD --» JDM PS Pump
Used
S2000 & RSX-S 11.8" Brake Upgrade - for a 4thGen Prelude, with Axxis Metal Master Pads.
P14 ECU - USDM H23A1
PSpec Tuning Stickers x 4 (Buy something & Free, otherwise Pay Shipping.)
USDM Mirror Switch - 4thGen
H22 Auto Starter - Starter 1 | Starter 2
USDM Side Mirrors Units (No Covers or Mirrors) - 4thGen
Antenna & Full Cable - Doesn't move up or down, 4thGen
Stock 4thGen Si Front Rotors, Lines, Pads (Front & Rear)
Stock Shift **** & Boot - 4thGen
Driver Side Outside Turning Signal - 4thGen - Signal 1 | Signal 2
Stock Acura Radio - with Code, Double Din. - Deck 1 | Deck 2 | Deck 3
Clutch Master Cylinder, Stock Clutch Fluid Hard Line and Damper - 4thGen, used.
SOLD --» VTEC 6x9 Sub Assembly (3 Black, 1 Tan)
SOLD --» Rear Passenger Side Panels
SOLD --» 5thGen 5-Lug Conversion
SOLD --» Carbon Fiber Tail Lights
SOLD --» VTEC Center Console
SOLD --» Cup Holder x 2
SOLD --» Stock Shifter
SOLD --» TPS Sensor
SOLD --» Main Relay
Audio
Failed Trade --» 2 x Sony Xplod 12" Subs, Model Number: XS-L122P5
Failed Trade --» Sony Xplod Amplifier XM-2200GTX
Given to Girlfriends Brother --» Pioneer 3.5" 2 Way, Model Number: TS-G1041R
Given to Girlfriends Brother --» XD7500 Dual Head Unit
Given to Sister's BF --» Wiring
SOLD --» Two 12" Sub Box
Modified by MLBZ521 at 11:33 PM 2/5/2008
Modified by MLBZ521 at 12:56 PM 2/11/2008
Modified by MLBZ521 at 1:11 PM 2/12/2008
Modified by MLBZ521 at 12:21 AM 2/17/2008
Modified by MLBZ521 at 6:49 PM 2/22/2008
Modified by MLBZ521 at 5:25 PM 3/2/2008
Modified by MLBZ521 at 12:55 PM 3/6/2008
Modified by MLBZ521 at 12:32 AM 3/11/2008
Modified by MLBZ521 at 7:05 PM 3/11/2008
Modified by MLBZ521 at 4:02 AM 3/19/2008
Modified by MLBZ521 at 5:52 PM 3/21/2008
Modified by MLBZ521 at 2:23 PM 3/27/2008
Modified by MLBZ521 at 3:47 PM 3/31/2008
Modified by MLBZ521 at 3:04 PM 4/2/2008
Modified by MLBZ521 at 8:29 PM 4/8/2008
Modified by MLBZ521 at 3:42 PM 6/14/2008
Modified by MLBZ521 at 1:34 PM 9/14/2008
Modified by MLBZ521 at 6:11 PM 11/16/2008
Old Feb 1, 2008 | 02:13 PM
MLBZ521's Avatar
Default Wanted Parts
NO LONGER NEED ANY OF THIS, Sorry
Mostly 4thGen Parts. ALL Interior Pieces bust be Black.
Need the following parts to fix my car after it being stolen.
Rear Brake Dust Shields - Need Both Sides - Acquired
Passenger Side Cornering Light - Will take both corners if need.
Front Driver Side Bumper Turning Signal (Clear) - Will take a entire set if need.
Passenger Side Grill Nostril - Will take both sides if need.
White Front Bumper (Prefer Local)
Also looking for:
- Hood Hinges
- Inside Fuse Box Cover
- Console Lid ('94 - '96 Version)
- Rear 5thGen Rotors (Prefer New)
- Front Acura RL '99 - '00 Rotors (Prefer New)
- The Trim piece in the Trunk that covers the edge where the latch is.
- Passenger Side Rear Side Panel - Must be in perfect condition, don't care/need insert.
- Driver & Passenger Side Front Fender Liners & Rear Passenger
- Drivers Door Weather Stripping, Both Door & Frame - Must be in perfect condition
- Trunk Weather Stripping - Must be in perfect condition
- I need the External Coil Mounting Bracket. Acquired
- I could use the Bolt that holds the Dip Stick Tube to the Engine Block..
- All Clips, Connectors, and Rod itself for the Hood Prop Rod.
- Need the Passenger Door Latch/Lock Mechanism with the Linkage/Rods still attached. (More interested in the Rods, but removing them from the Door Lock Mechanism could break them..)
- The Rod that connects the Key Lock to the Rear Seat to drop the seat down from inside the car. If it can be removed without breaking it.. I'd take the whole Mechanism if necessary..
Other parts I'm looking for:
I'd like this stuff, but more worried about the previous parts mentioned.
- Suspension, Koni Yellows & Ground Control
- Hood Dampers, will consider sets not specifically for a Prelude also.
- 5thGen 5-Lug Swap - Acquired
- 5thGen Sun Roof Assembly
- Cheap eBay CAI Piping, will consider AEM/Injen CAI's also, I want 3" Piping Minimum.
If someone local had the following, I might get them.
- White Hood
- White Driver Side Front Fender
- White Rear Bumper
- White WingLESS Trunk
Old Feb 1, 2008 | 02:14 PM
MLBZ521's Avatar
Default Vouch List
Vouches
I've sold a multitude of parts here on Honda-Tech, and some on a local board for the Memphis, TN area. If you've bought from me or I've bought from you let me know and I'll add ya..
Honda-Tech:
Sold To: E-Money, Elviejoracing, Televator(*3), jdmh22aprelude, K-Spec(*2), 96_CD5, StarBai, ludetech, kornkid21792, meanshyguy, z31k, J-SPEC LUDE, IMPORTMyth01, NXSpoon, Bucks, 95blackegcoupe, VTecLude1994, twophastprelude, BUILT93ludeSi, Prudz_lude, .BigSexy, studio718, botlebruiser, FLATBUSH PROJECTS, JT, goku, cow1787, ProjectBB6, veetak(*2), TylerC161, 2fastGSR, NowABeliever, luder94-ChrisA, 2001turbobluelude, street_ride14, DCxMagus, tboone325, muggins, sidthakid, LudeJdm, TreWatts, WhiteBB2(*2), kornerk12, Rosko, ShinobiLude, ragethemachine86, IAluder95, KillerAccord, Spn_BB2
Bought From: SpoonCivicSir20, pprowler6, Televator, mgags7, coupej1, 2point6(Scott)@CollectiveRacing.net, EvasiveMotorsports.com, preludestud11, Opossum Jenkins, DC4KiD, scrip2nite, lude27, boostedblkef, K-Spec, CleanLude, TheWalrus, tdo
AZHT.net:
Sold To: krazyblurtz, 9kshifter, 97hondaprelude, Charlee, Vtec_IN_3RD, bmxican, jdm ek9, YuckerDisMe, Five_ten1995
Bought From: BBSick, nestor
PreludeOnline.com:
Sold To: TJ97SH, mooncaller, preludeboris11, cballin25ltown
Also Great Experience with:
Collective Racing, ImportRP.com, EvasiveMotorsports.com
eBay Feedback 100%
Paypal Verified
Old Feb 3, 2008 | 09:11 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: (MLBZ521)
good guy
Old Feb 4, 2008 | 08:04 AM
MLBZ521's Avatar
Default Re: (Mr.OB*GYN_Rhett)
Thanks Rhett, same to you!
Old Feb 4, 2008 | 05:31 PM
RhdRicheeee's Avatar
Default Re: «-- MLBZ521's For Sale Thread --» Prelude Engine, Exterior, Interior, & Other Parts! (MLBZ521)
Old Feb 5, 2008 | 12:56 PM
MLBZ521's Avatar
Default Re: (RhdRicheeee)
Thanks man!
Old Feb 5, 2008 | 08:20 PM
Televator's Avatar
D'oh! I missed the car cover!
Old Feb 5, 2008 | 09:34 PM
MLBZ521's Avatar
Default Re: (Televator)
You needed one of those?? Should have said something..
<FONT COLOR="Blue">SOLD --»</FONT>Stripped JDM H22A Intake Manifold
Old Feb 8, 2008 | 10:27 AM
Televator's Avatar
Hopefully you can join our parts raid so you can join our parts raid this weekend.
Old Feb 8, 2008 | 11:44 AM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Televator &raquo;</TD></TR><TR><TD CLASS="quote">Hopefully you can join our parts raid so you can join our parts raid this weekend. </TD></TR></TABLE>
I have to ask, What the heck did you just say????
Old Feb 8, 2008 | 02:18 PM
Televator's Avatar
LOL! I'm spinning in circles here at work. I meant: Hopefully you can sell some parts so you can join our parts raid this weekend.
Old Feb 9, 2008 | 10:27 AM
MLBZ521's Avatar
Uh huh... Or Hitting the crack pipe?
We'll see what happens... It's been a bad week or two, so I'm not sure right now..
I do hope I sell some stuff though..
Old Feb 11, 2008 | 10:57 AM
MLBZ521's Avatar
<FONT COLOR="Blue">SOLD --»</FONT> JDM M2B4 Starter
Old Feb 11, 2008 | 12:21 PM
WingDC2R's Avatar
Buy all of these parts!!!!!
Old Feb 12, 2008 | 11:12 AM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WingDC2R &raquo;</TD></TR><TR><TD CLASS="quote">Buy all of these parts!!!!!</TD></TR></TABLE>
Thanks man! Slowly but surely..
<FONT COLOR="Blue">SOLD --»</FONT> AEBS Head Studs & Socket
<FONT COLOR="Blue">SOLD --»</FONT> JDM Distributor TD-60U (Used)
Old Feb 12, 2008 | 09:24 PM
sup3rd's Avatar
still need an egay cai? I've got one for my 5th gen. I don't know if it'll fit but I'll let it go for amazingly cheap..
Old Feb 13, 2008 | 10:41 AM
MLBZ521's Avatar
^^PM'ed.
Old Feb 16, 2008 | 10:27 PM
MLBZ521's Avatar
<FONT COLOR="Blue">SOLD --»</FONT> JDM PS Bracket
Old Feb 17, 2008 | 03:48 PM
BUILT93ludeSi's Avatar
how much do you want for the 345cc injectors?
Old Feb 17, 2008 | 10:11 PM
MLBZ521's Avatar
^^PM'ed!
Old Feb 19, 2008 | 02:11 PM
Televator's Avatar
I'll have a liter of cola.
Old Feb 20, 2008 | 01:26 AM
MLBZ521's Avatar
Oh? I'm kinda lost here.. Just slightly..
Old Feb 20, 2008 | 02:03 PM
Televator's Avatar
It's from Super Troopers...Funny ****. Haha!
Old Feb 20, 2008 | 07:37 PM
MLBZ521's Avatar
Oooh.. Haven't seen that movie in awhile...
