Suspension & Brakes Theory, alignment, spring rates....
Which sway bar to use?
Old Feb 1, 2008 | 01:27 PM
vacantskies88's Avatar
Default Which sway bar to use?
I'm asking for a friend.
1991 Civic Si with the rear disc conversion from a 93 teg.
He's looking to get a Progress rear sway bar. They make a 22mm (62.1002) and 24mm (62.1001) for the CRX and a 22mm for a DA teg (62.0101). Which one should he be using?
He also has MFactory lower control arms, toe & camber adjusters if that matters.
Thanks in advance
Old Feb 1, 2008 | 08:26 PM
Default Re: Which sway bar to use? (vacantskies88)
Hmm.... I found out the 24mm rears share the same part number between the EF & DA but the 22mm bars have different numbers?
Old Feb 2, 2008 | 06:56 AM
Anyone?
88 EF Hatch
20
May 3, 2009 01:12 PM
fireant
14
Apr 12, 2006 11:43 AM
lowbOOsted
Dec 5, 2005 05:37 AM
andyvaj
Mar 18, 2005 09:51 PM
katb16vo
Mar 22, 2004 02:17 PM
