fixing carbon fiber?
Old Jan 31, 2008 | 07:09 PM
recon23's Avatar
Default fixing carbon fiber?
My brother has a carbon fiber wing on his evo. The clear coat is coming off a little, and is turning white. I know its for an evo, but the Mitsubishi guys arent as helpful as the honda guys. How can I fix this problem. I heard theories or wet sanding and buffing. Is this possible?
Old Jan 31, 2008 | 07:18 PM
em1_sir's Avatar
Default Re: fixing carbon fiber? (recon23)
if possible sand the peeling clear back and the white as well and reclear.
you can try buffing but a friend of mine picked up a itr with cf hood from a dealership and they buffed the hood before the sale and it gave it a white faded look to it.
Old Jan 31, 2008 | 08:31 PM
luvtositdumpt's Avatar
From: somewhere in the d, mmm stake, mmm country fried stake
best bet would be to sand down most of the clear, be careful not to hit the weave...not just the part thats fading but the whole wing...start with 320...work your way up to bout maybe 600 then reclear....make sure all sanding is done wet and is uniform
Old Feb 3, 2008 | 07:36 AM
SiZ's Avatar
SiZ
Its okay to sand the weave, you'll have to sand it for a quite a while to burn through. A good way to tell if you do sand it down to the weave is the shape of the weave will start to distort as you start to sand through the carbon. Its probably fading/oxidizing because its not clear coat on there. Sand it, clear it, good to go.
Old Feb 4, 2008 | 09:55 AM
Nicks95GSR's Avatar
Default Re: (SiZ)
any pics??? same happening to my CF hood...
Old Feb 5, 2008 | 07:34 PM
perseverance's Avatar
my buddy had his covered under warranty. check ur dealership...easiest way out of that mess. lol
Old Mar 6, 2008 | 06:28 AM
recon23's Avatar
Default Re: (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">my buddy had his covered under warranty. check ur dealership...easiest way out of that mess. lol</TD></TR></TABLE>
Are u serious?!
They jerked him around when his Brembos clear started to crack.....saying that it didn't impede on the "function" of the breaks.
If u are right I guess its worth a shot......
Old Mar 8, 2008 | 01:48 AM
mafioso619's Avatar
i got the same problem on my eg hood and its actually a seibon hood. just the area close to the driver side, the rest still looks good. bought it new about 2 years ago. also had heard about sanding down and a new clearcoat. how much would that run at a body shop if they do it. any ideas, thnx
Old Mar 10, 2008 | 07:12 PM
JoshEM2's Avatar
So i have a hole in my carbon fiber front end is it possible to fix it ?
Old Mar 13, 2008 | 04:25 AM
RoadRage212's Avatar
Default Re: (JoshEM2)
A hole in a C/F hood? NO. Put your hood latch pins back in and forget about it.
As far as your wing is concerned, you probably don't need to sand it. Go to a paint supply place and get a buffing compound for marine/gel coat applications. This and a good wool pad with a variable speed buffer should take care of it. As long as the clear isn't peeling you should be fine. If it is peeling, then sanding is necessary first.
Old Mar 13, 2008 | 09:26 AM
recon23's Avatar
Default Re: (RoadRage212)
We would defff be sanding the wing..........so many EVOs suffer from this that
when u see one that isn't its like
Old Mar 13, 2008 | 12:54 PM
Default Re: (recon23)
Yeah I've seen what you're talking about. But you'll still need a marine or gel coat application buffing compound because I've done this to a lot of hoods and buffing wetsand marks out of c/f is a beeaatch. Just take your time and be careful. It sounds repairable but it would help if you posted pics.
jrsh0526
Nov 1, 2011 03:48 PM
snowskater34
Paint and Body
13
Apr 1, 2009 12:15 AM
EG-boy
Paint and Body
14
Mar 3, 2009 08:48 PM
hbkxtbone
Apr 4, 2007 07:09 AM
menappi
Jan 22, 2004 11:10 PM
