code 17 after d16z6 swap
Old Jan 31, 2008 | 03:46 PM
nfereorhatch's Avatar
Default code 17 after d16z6 swap
I have searched and read several threads on the subject but i didn't find a answer that really put my mind at ease so i'm asking again. My speedometer works fine but every now and then i get code 17 on deceleration. I can't say if vtec is engaging because i honestly don't know (could hear clearly it on my b16). The ? is does this code keep vtec from engaging and if so what causes it when the speedometer is working and the car is running fine?
Old Jan 31, 2008 | 07:51 PM
GSX 4G63T's Avatar
Accord Civic CRV CRX Del Sol Odyssey Prelude
88-98 88-98 97-98 88-91 93-97 95-97 88-98 VSS (Vehicle Speed Sensor)
defective circuit or unplugged / defective sensor
Old Jan 31, 2008 | 08:10 PM
alscrx's Avatar
Default Re: code 17 after d16z6 swap (nfereorhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfereorhatch &raquo;</TD></TR><TR><TD CLASS="quote">I have searched and read several threads on the subject but i didn't find a answer that really put my mind at ease so i'm asking again. My speedometer works fine but every now and then i get code 17 on deceleration. I can't say if vtec is engaging because i honestly don't know (could hear clearly it on my b16). The ? is does this code keep vtec from engaging and if so what causes it when the speedometer is working and the car is running fine?</TD></TR></TABLE>
Yes this stops vtec from opperating! You need to fix code 17. Check your cable going into the tranny. There is a clip that holds it on. Make sure you can't pull out the cable by hand. If its in there tight check you speedo where in plugs into.
Kaan
Sep 26, 2005 11:31 PM
wrXtian
Jul 26, 2005 08:28 AM
E36 Guy
Dec 9, 2003 10:21 PM
E36 Guy
Dec 9, 2003 08:49 PM
