ELECTRICAL PROBLEM IN 88 CRX
Old Jan 31, 2008 | 12:09 PM
jitr's Avatar
Default ELECTRICAL PROBLEM IN 88 CRX
I'M NOT THE ONLY ONE WHO HAS HAD THIS PROBLEM... I JUST BOUGHT THIS CRX, AND WHENEVER I HIT THE BRAKES, THE SEAT BELT ALARM SOUNDS AND THE SEAT BELT LIGHT AND THE DOOR LIGHT COMES ON. I NEVER FOUND OUT WHY THE OTHER GUYS WAS DOING IT. DOES ANYONE KNOW WHY THIS IS HAPPENING SPECIFICALLY. OBVIOUSLY IT COULD BE A LOOSE GROUND OR WIRES CROSSED SOMEWHERE... SINCE IT HAS HAPPENED TO OTHER PEOPLE THOUGH, I WANT TO KNOW EXACTLY WHY THEIRS WAS DOING IT. THANKS SO MUCH!!!
Old Jan 31, 2008 | 12:16 PM
CRX Toad's Avatar
Default Re: ELECTRICAL PROBLEM IN 88 CRX (jitr)
Please
Old Jan 31, 2008 | 12:40 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
THE HORN/STOP FUSE UNDER THE HOOD IS USUALLY THE CAUSE
OF THIS...
Old Jan 31, 2008 | 05:01 PM
CR91X's Avatar
Default Re: ELECTRICAL PROBLEM IN 88 CRX (88DXCRX)
happend to me like 2-3 times it's the fuse #15? under the hood the horn/stop just get new fuse buy some extras in case it keeps happening ...one time it happen to me I replaced it few sec. later same crap so wouldn't hurt to buy the packs more than enough
Old Jan 31, 2008 | 06:36 PM
jitr's Avatar
Thanks 88dxcrx and cr91x. I really appreciate it. I have a bunch of spare fuses, and it fixed the problem!! Would this also cause the battery to drain, or was it just an annoying problem?
Old Feb 1, 2008 | 04:39 PM
CR91X's Avatar
Default Re: (jitr)
not too sure on battery drainage though i guess if you don't fix it and keeps beeping or what not would probably drain it bit by bit but just the damn annoying noise
Old Feb 1, 2008 | 05:35 PM
wood 1's Avatar
Default Re: (jitr)
I had a problem with battery drain and one day I took the negative battery cable off and when I went to reconnect it, I heard a clicking noise. I just touched the cable to the post a number of times until I found what the problem was. In my case it was wiring to the right seatbelt in the door. After I unplugged this, my problem was gone. Not saying this is your problem but by repeatedly touching the cable to the battery you may see or hear where your problem is coming from.
Booz
18
Aug 14, 2013 07:53 AM
switters959
Nov 27, 2011 12:17 PM
jfrank05
Aug 10, 2008 05:34 PM
unabonger
Oct 4, 2002 11:58 AM
