help with O2 Sensor wire colors and meaning
Old Jul 2, 2002 | 03:31 PM
00-ITR-373's Avatar
Default help with O2 Sensor wire colors and meaning
So, I was all set to use the picture below. and solder inline a resistor and capacitor to fool the O2 sensor (in case you don't have a cat).
It lists the wire colors as 2 white, 1 grey, and 1 black.
I take the sensor off and have 2 black, 1 white, and one green.
Anyone have any good guesses as to which is which?
Or...is there anyway I can leave the O2 Sensor out and read "fresh" engine bay air. I'm thinking this might think the engine is running lean if It senses too much oxygen?
Old Jul 2, 2002 | 03:40 PM
00-ITR-373's Avatar
Default Re: help with O2 Sensor wire colors and meaning (00-ITR-373)
Alrighty....so far I've found
White = sensor signal
Green = sensor ground
Now any guesses as to which color takes the resistor in line?
Old Jul 2, 2002 | 06:23 PM
EVIL Hx Coupe's Avatar
I just unplugged my o2 sensor, now u talk about running lean or rich.... do you think taking the 02 sensor off may cause the car to hessitate when u shift.
Old Jul 2, 2002 | 08:25 PM
00-ITR-373's Avatar
Default Re: help with O2 Sensor wire colors and meaning (Boost Pressure)
Unplugged the sensor from the bung....(or unplugged the coupler? guessing no).
Hmmm..I don't know if it'd cause the car to hesitate when shifting.
Old Jul 2, 2002 | 11:39 PM
OGekCivic's Avatar
I'm also looking for an o2 sim. Where did you find that diagram? You need this for the 2nd o2 sensor for and OBDII car correct? Check out what I've found below. Let me know where you got that info and if that mod worked.
http://www.casperselectronics.com/cg...roduct=IMPORTS
http://jdmfan.com/technical/performa...sor_simulator/
http://www.diabloautosports.com/prod...oducts_id=2198
Good Luck
GM
Old Jul 3, 2002 | 06:27 AM
Avante's Avatar
Default Re: help with O2 Sensor wire colors and meaning (OGekCivic)
Like you said, the white and green wire are for the O2 Sensor Signal, the two black ones are just for the O2 sensor heater. If you do get an O2 sensor Sim like the ECG you have to put a 1k ohm resister on the heater wire circuit. Even if you put an O2 sensor sim in, if you leave the Heater wires open, or dont put in a resistor you will get a CEL almost immediatley after you start your car/
Old Jul 16, 2002 | 04:06 AM
00-ITR-373's Avatar
Default Re: help with O2 Sensor wire colors and meaning (Avante)
Why? Not saying you're wrong, just wondering why you say this. I was told not to touch those two wires. That the only two wires doing any sending/receiving (the only ones that would theoretically matter) were the green and white wires, not the heater signal wires.
Thanks for any info you have.
minituner
Mar 26, 2016 04:16 PM
luis31
Nov 14, 2006 02:55 PM
BLUE EH3
May 16, 2005 07:24 PM
LsTurbo91
Oct 8, 2001 09:20 PM
