JDM OEM HIDs on a 97?
Old Jan 31, 2008 | 09:25 AM
Loud-N-Clear's Avatar
Default JDM OEM HIDs on a 97?
Just a quick yes or no question. I heard from someone that the OEM HID headlights don't fit on USDM 97 Type-Rs because the ABS system gets in the way of the ballasts. Is this true, or will these headlights work on a 97 as they would any other ITR?
Old Jan 31, 2008 | 09:57 AM
evertp1's Avatar
Default Re: JDM OEM HIDs on a 97? (Loud-N-Clear)
im sure you can locate the ballasts can be located any where you want it to be?
Old Jan 31, 2008 | 10:05 AM
jomama's Avatar
Default Re: JDM OEM HIDs on a 97? (evertp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evertp1 &raquo;</TD></TR><TR><TD CLASS="quote">im sure you can locate the ballasts can be located any where you want it to be?</TD></TR></TABLE>
i would think this, too. the issue would be fitting the projectors correctly in the 97 housings. then again, why ruin a set of jdm headlights for the projectors unless they're messed up already when you can use: tsx, a6, e55, bmw, s2000, etc. projectors? GL
Old Jan 31, 2008 | 10:11 AM
Default Re: JDM OEM HIDs on a 97? (jomama)
Sorry, I don't think I made myself clear enough. I have a JDM front end on my 97 ITR and I want to install the whole HID headlights, not just the projectors. I had just heard that the placement of the ABS on 97s would get in the way of running these headlights.
Old Jan 31, 2008 | 10:20 AM
KOALA YUMMIES's Avatar
The 1997 US ITR ABS is the same as the 98+ smaller ABS units.
EG6-DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loud-N-Clear &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, I don't think I made myself clear enough. I have a JDM front end on my 97 ITR and I want to install the whole HID headlights, not just the projectors. I had just heard that the placement of the ABS on 97s would get in the way of running these headlights.</TD></TR></TABLE>
So this is a USDM 97 ITR? Or is this a USDM 97 Integra?
If it is a real 97 ITR, then the headlights will fit. If it is a fake R, then it will not fit. The newly designed ABS unit was only on the ITR in 97. Now if it was a JDM ITR and had ABS and was a 97, then the HID's will NOT fit. The JDM ITR's did not get the redesigned ABS unit until 98.
Old Jan 31, 2008 | 10:55 AM
coolhandluke's Avatar
Default Re: JDM OEM HIDs on a 97? (EG6-DC2)
Good info from a guy who knows. Check the sig
Old Jan 31, 2008 | 11:04 AM
iheartintegras's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
If it is a real 97 ITR, then the headlights will fit. If it is a fake R, then it will not fit. The newly designed ABS unit was only on the ITR in 97. Now if it was a JDM ITR and had ABS and was a 97, then the HID's will NOT fit. The JDM ITR's did not get the redesigned ABS unit until 98. </TD></TR></TABLE>
good info. Can't believe we actually got something before Japan did!
Old Jan 31, 2008 | 11:11 AM
EG6-DC2's Avatar
Default Re: JDM OEM HIDs on a 97? (iheartintegras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartintegras &raquo;</TD></TR><TR><TD CLASS="quote">
good info. Can't believe we actually got something before Japan did!</TD></TR></TABLE>
Not to mention us getting the 5x114 before Japan did.
Or the fact that we got the ITR before the rest of the world, besides Japan.
There are plenty more things that are different between the 2 97 R's and they aren't the obvious things such as a different front end.
Old Jan 31, 2008 | 11:17 AM
It's pretty cool that you have two 97'Rs, each one from two different sides of the world and two different configurations.
standy xsi
Dec 13, 2011 12:41 PM
bmwe362006
Jan 24, 2011 10:13 AM
minhty
Aug 28, 2007 11:35 AM
ITR43
Apr 23, 2006 08:12 AM
crxhybrid1320
Mar 23, 2003 09:23 AM
