Identifying a brake upgrade?
I purchased my wagon with a 10.25" brake upgrade in the front. Now, the guy I bought it from claimed it was a EX knuckle with ITR calipers (which I read is a possible combination). My question is, what do I look at to find out if those are indeed the parts? The rotors are fubarred and I'm gonna do the front brakes anyways cause I'll be replacing the bearings and driveshafts, so I might aswell do it all.
Is the EX rotor the same as a 90 Teg? Are the ITR pads the same as a EX caliper pad?
Local autoparts store listed different numbers for all the parts. So I'm really confused.
EX rotors = DA rotors
ITR pads are not the same as EX pads.
Measure the size of the rotors if is it is 10.25" that is EX if it is 11.1" that is going to be a redrilled Legend or Prelude rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roastbeefrichie »</TD></TR><TR><TD CLASS="quote">
the itr calipers are stamped: 1 7 C L 1 5 V N
Street Racer X, you can use the accord wagon calipers & as CRX Toad mentioned, the Legend calipers will work as well. the 17CL15VN caliper can also be found in junkyards (i.e., +97 prelude, accord, cr-v, vigor, rl, tl, cl, odyssey, etc). get the ITR calipers with the brackets
you'll need the 23T or 25T bracket
the itr calipers are not a bolt-on. the bolt pattern for the bracket & knuckle are the SAME, but the offset is different. if you were to try to bolt it on directly, the bracket would get caught on the rotor & the wheel would not be able to spin. the 23T (or 25T) bracket will need to be sent to the machine shop, where they'll mill approxiamately 2-3 mm (or 1/8") off (where the bracket mates with the knuckle).
[B]https://honda-tech.com/zerothread?id=1484555
https://honda-tech.com/zerothread?id=734560
https://honda-tech.com/zerothread?id=1811368
the milled 23T (or 25T) allows you to use the ITR caliper (1-pot), legend GS (2-pot) or NSX calipers w/ 11" rotors on EX knuckles; they all share the same size pads
the milled 23T (or 25T) allows you to use the ITR caliper (1-pot), legend GS (2-pot) or NSX calipers w/ 11" rotors on EX knuckles; they all share the same size pads </TD></TR></TABLE>
aalouie
13
Nov 6, 2008 05:36 PM
likenother
Sep 13, 2007 11:42 AM
red civic standard
May 12, 2003 06:38 PM
