eg rear lower arm bar fit ed/ef crx?
i had a quick look but didnt see any definitive answers.
will a eg lower arm bar fit on a crx? with or without mods?
i've seen a few comments they do, but i'd like to see some pics or first hand comments before i blow my money on something i cant use.
yes they do. as an example the skunk2 rear lca have the same part #. it should be a perfect fit.
Modified by GSR CRX at 11:35 AM 1/31/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panda[cRx »</TD></TR><TR><TD CLASS="quote">]i know the skunk2 ones fit, yet nobody has been able to gimme an answer on other brands ie. carbing, beaks etc etc</TD></TR></TABLE>
x2 ...id really like to know if the beaks will fit
bump<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecd0304 »</TD></TR><TR><TD CLASS="quote">
x2 ...id really like to know if the beaks will fit</TD></TR></TABLE>
or ASR....
or ASR....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing »</TD></TR><TR><TD CLASS="quote">Is there any advantage like getting more caster?</TD></TR></TABLE>
How can a rear lower control arm give you caster?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip »</TD></TR><TR><TD CLASS="quote">no the beaks will not work without modifying the brace or the chassis.</TD></TR></TABLE>
do you know off hand what mods need to be made?
From: Where the wild things are in, NY, United States of America
there is no mods to fit it short of mutilating the bar or your subframe. Want a stiffer rear? go make a similar piece out of flat stock mild steel. it'll be stronger cause you won't have to hack the **** out of it and considerably cheaper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 yellow crx »</TD></TR><TR><TD CLASS="quote">Will work unless you have a 88 crx si. 88 si has the same rear end setup as a itr and there are no lower control arms for that setup.
Way to thumbs down a part that has nothing to do with what we're talking about. LCAs and Lower braces aren't the same thing.
for your ability to read. Thanks and try again.
THE REAR SUBFRAME BRACE IS A DESIGN THAT NEEDS TO BE FOR THE SPECIFIC CHASSIS.
^^^^ WILL NOT WORK ON ANY 88-91!!!^^^^^
/thread
</TD></TR></TABLE>Way to thumbs down a part that has nothing to do with what we're talking about. LCAs and Lower braces aren't the same thing.
for your ability to read. Thanks and try again. THE REAR SUBFRAME BRACE IS A DESIGN THAT NEEDS TO BE FOR THE SPECIFIC CHASSIS.
/thread
Didn't know they made a style like that? I'm used to the one pieces like above.What company is that? What do you need to modify on that? And why is your fuel filter there?
oh i can see that its not a regular style fuel system, i just wouldn't think you'd want your fuel filter hanging out like a set of bull *********. nice set up nonetheless.
hondata760
Aug 7, 2012 08:24 PM
honda_coupe
10
Nov 29, 2008 09:18 AM
juice91si
13
Jul 11, 2006 09:34 PM
