crx hood
i need help on my crx hood...i close the hood and now the latch is stuck and i cant get the hood to open. any help on how to get the latch off so i can open the hood..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Try to reach under the bumper to see if you can pull the cable to release it. If not, you need to try to get under the car and release the latch with a screwdriver.</TD></TR></TABLE> Probably best thing to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Try to reach under the bumper to see if you can pull the cable to release it. If not, you need to try to get under the car and release the latch with a screwdriver.</TD></TR></TABLE>ditto, there should be a black cable that goes accross your AC condensor right behind the bumper. you want to pull that cable only from the side that goes to the latch (under the hood), as hard as you can. if that doesnt work. have a friend push the front of the hood down while you pull the hood release latch.....actually try that first then try the cable pulling trick. p.s. search a bit, there's a million threads on it.
Modified by I CRX I at 4:49 AM 1/31/2008
Modified by I CRX I at 4:51 AM 1/31/2008
Modified by I CRX I at 8:55 AM 2/1/2008
AnotherDay562
26
Jan 27, 2008 07:20 AM
Bserieskllr
10
Jan 20, 2007 10:14 PM
brentmc79
Jan 14, 2005 09:23 AM
GroundZer0
May 22, 2003 03:43 PM
