transmission
Old Jan 30, 2008 | 03:51 PM
ls eg's Avatar
Default transmission
ok this might already have a post but i cant find it maybe im wording it wrong, but how do i bleed my hydro tranny
Old Jan 30, 2008 | 03:56 PM
z6hatchboy's Avatar
Default Re: transmission (ls eg)
Pump the clutch pedal, then go to the front where the actuator is on the tranny and there is a 8mm bleeder valve, loosen just enough for the air/fluid to come out then tighten again. Then repeat and add fluid, until the clutch returns to how it previously was.
Old Jan 30, 2008 | 03:59 PM
Ej Girl's Avatar
what you do is you get someone to sit in the front seat and pump the clutch pedal like 10 times fast and at the end of the pumping they have to hold the pedal all the way down as you open the bleed screw and let it flow out (they cannot let up on the pedal untill the screw is closed!!). once the fluid stops coming out close the screw and repeat until the pedal is stiff.
Old Jan 30, 2008 | 04:01 PM
z6hatchboy's Avatar
Default Re: transmission (Ej Girl)
True, i forgot to mention having someone hold it down.
Old Jan 30, 2008 | 04:11 PM
ls eg's Avatar
ok so i have someone pump the pedal then i open the screw while they hold the pedal and let all the air/fluid dran out then tightin the screw back then refill the fluid ..correct?
Old Jan 30, 2008 | 04:16 PM
Ej Girl's Avatar
thats right.
Old Jan 30, 2008 | 04:17 PM
z6hatchboy's Avatar
Thats it.
Old Jan 30, 2008 | 04:19 PM
ls eg's Avatar
alright thanks alot guys
Old Jan 30, 2008 | 04:27 PM
Ej Girl's Avatar
NP GL and have fun!
starquestchris
Mar 23, 2010 10:25 AM
obuhmyuh
Nov 5, 2007 09:42 PM
tbuck23
Apr 3, 2007 01:27 PM
1SlowSi
Aug 16, 2005 07:24 AM
carblegal
Mar 24, 2003 08:24 PM
