Transmission Countershaft Speed Sensor?
I jumped the service connector and i have a code 9 when the D4 flashes. After getting the code from anothe site I found out its the countershaft speed sensor. Now my problem is that i have no idea where this sensor is located at. Can someone point it out for me in a pic. Thanks
Oh btw here's the link to get the code's
http://home.earthlink.net/~mic...s.htm
I've had a few of those problems wind up being poor connections at the couplers.
You can remove it from the trans tail housing and clean all the crud off of it.
If my old memory is working, those wires also go thru a multi-pin connector on the top of the passenger side fender well.
blastingas10
Transmission & Drivetrain
Jun 18, 2015 12:14 PM
