Suspension & Brakes Theory, alignment, spring rates....
Quick question about koni yellows....
Old Jan 30, 2008 | 02:54 PM
bmoua's Avatar
Default Quick question about koni yellows....
My uncle wants to pick up a set of koni yellows for his DA, he already has skunk2 slip over coilovers and wants to pair them with the koni's. I was told the sk2 coilovers will not sit right onto the koni's shock body? Also they will void koni's warranty? LMK guys thx
Modified by bmoua at 4:06 PM 1/30/2008
Old Jan 30, 2008 | 03:08 PM
Targa250R's Avatar
be professional
Default Re: Quick question about koni yellows.... (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">My uncle wants to pick up a set of koni yellows for his DA, he already has skunk2 slip over coilovers and wants to pair them with the koni's. I was told the sk2 coilovers will not sit right onto the koni's shock body? Also they will void koni's warranty? LMK guys thx </TD></TR></TABLE>
You can't use Skunk2 coilover sleeves with Koni dampers.
As a matter of fact, the only coilover sleeves you should ever use with Koni dampers are 1) the Ground Control Koni-specific sleeves, 2) the regular GC sleeves with the special GC Koni adapters, or 3) Koni's own coilover sleeves.
No other coilovers on the market have the groove machined into the bottom of the sleeve to correctly capture and rest on the Koni circlip.
And after seeing cases of Skunk2's poor quality sleeves flaring out at the bottom under normal use, I wouldn't want to risk it. Having the suspension collapse while driving would be rather dangerous.
Old Jan 30, 2008 | 03:14 PM
bmoua's Avatar
Default Re: Quick question about koni yellows.... (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
And after seeing cases of Skunk2's poor quality sleeves flaring out at the bottom under normal use, I wouldn't want to risk it. Having the suspension collapse while driving would be rather dangerous.</TD></TR></TABLE>
thx for the confirmation bro...
sde780
Suspension & Brakes
Mar 2, 2011 06:39 AM
Goodbye My Love
Suspension & Brakes
Jul 12, 2005 08:32 PM
GradyDC5
Apr 15, 2004 11:33 AM
paulyman
Jun 25, 2002 06:07 PM
