does anybody have an rsx aftermarket Throttle body installed in their rsx
Old Jan 30, 2008 | 11:41 AM
hamster20's Avatar
Default does anybody have an rsx aftermarket Throttle body installed in their rsx
want to ask if you have to take your cruse control cable off.and the bracket on the stock Throttle body(the braket that holds your two cables in place)not the bracket on the manifold the bracket on the stock Throttle body.did you reuse it on the aftermarket one.
Old Jan 30, 2008 | 11:54 AM
hamster20's Avatar
Default Re: does anybody have an rsx aftermarket Throttle body installed in their rsx (hamster20)
<br/>
Old Feb 1, 2008 | 02:34 AM
risktypeS's Avatar
why would you want to install an aftermarket TB on a stock IM let alone stock block. Unless you have MAJOR mods and i mean MAJOR mods to support that aftermarket TB you're not going to get any gains. it's a complete waste of money.
Old Feb 2, 2008 | 06:25 AM
hamster20's Avatar
Default Re: does anybody have an rsx aftermarket Throttle body installed in their rsx (risktypeS)
cause im runnning high compression pistons stage 3 cams and rbc manifold a buddy club header and k pro
Old Feb 2, 2008 | 09:42 AM
NTCustoms's Avatar
get your stock one bored/tapered, it'll be much better.
Old Feb 2, 2008 | 10:43 AM
hamster20's Avatar
Default Re: (NTCustoms)
how much can u bore out to.how big is a stock tb
Old Feb 2, 2008 | 11:13 AM
NTCustoms's Avatar
i believe you can taper the intake side from 70mm down. then bore the manifold side to 65mm. port match and you're good...
pinoyboy204
May 17, 2012 07:24 AM
_kiid
Texas -OK -LA (Sales)
Jun 6, 2010 01:16 PM
BDL IND
37
Dec 9, 2005 11:20 AM
BDL IND
10
Jul 10, 2005 09:25 PM
