Water in headlights
My hatch has a problem with getting condensation on the inside of the headlights. This is the second set of headlights that this has happened to. Any ideas for getting rid of this?
Thanks for the feedback.
This second set is brand new. The other set had rock chips in them... I thought moisture was getting in through the small cracks.
Any other ideas would be hel[ful. Sealing brand new headlights seems like a waste.
I had this same problem. I found out it was the seal of the bulbs that was letting in moisture. I put some silicon grease on the o-rings and it stopped. You also have to watch for temperature change and condensation.
