brake booster question
Old Jan 30, 2008 | 09:06 AM
zccr-xsi's Avatar
Default brake bosster
ok i just put rear dics from an si on my crx hf when i start the car and press the brakes the idle seems to go up a tad prob like 100 200 rpms the drop back to 800.any ideal on what could be cause this?im thinking maybe the booster has a vac leak some where?
Old Jan 30, 2008 | 09:42 AM
sgallagher's Avatar
Default Re: brake bosster (zccr-xsi)
Sounds like a leak in the diaphram of the brake booster. You might even be able to hear an air leak inside the car(under the dash).
Old Jan 30, 2008 | 10:07 AM
zccr-xsi's Avatar
nope i cant hear anything.it didnt do it with the hf drums.
Old Jan 30, 2008 | 11:56 AM
thesmogman's Avatar
Default Re: (zccr-xsi)
To check it properly you need a vacuum pump and apply 18in.hg. to the brake booster and see if it holds a vacuum.
When switching to discs from drums you need the proportioning valve too.
Old Jan 30, 2008 | 12:07 PM
sgallagher's Avatar
Default Re: (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">To check it properly you need a vacuum pump and apply 18in.hg. to the brake booster and see if it holds a vacuum.
When switching to discs from drums you need the proportioning valve too.</TD></TR></TABLE>
Old Jan 30, 2008 | 03:53 PM
zccr-xsi's Avatar
yea i got the entire trailing arms si cables and si proportion valve.
haha fyi it was FREE all i had to do is switch them out with my hf drum brakes.
duh702dc2
Suspension & Brakes
Dec 5, 2014 11:53 PM
cityofcaterpillars
Jun 12, 2010 02:15 AM
ogawa_jiei
Oct 9, 2006 01:57 PM
swiftstyles
Jan 12, 2004 02:12 PM
