Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
do the tl/cl have trans problems?
Old Jan 30, 2008 | 06:58 AM
crxcess's Avatar
Default do the tl/cl have trans problems?
I was thinking of picking up a tl or cl, but a friend of mine, who works in a auto repair shop, said to stay away from the v6 hondas and acuras. he says that they have trans problems and replacing them is expensive.
he gave me a a few examples of cars his family owned, including a tl that just had a trans replaced, and a odyssey that is on its 3rd trans and is starting to act up again.
so is this a known issue to the tl/cl community?
Old Jan 30, 2008 | 12:18 PM
Eg6_RcR's Avatar
Default Re: do the tl/cl have trans problems? (crxcess)
it's a known issue with the cl/tl's but you'll get better responses at acurazine.com
Old Jan 31, 2008 | 12:25 PM
Mashimaro's Avatar
it's more of a common issue with the pre '04+ TL/CL's...but only in the automatic ones.
Old Jan 31, 2008 | 05:17 PM
YeuEmMaiMai's Avatar
any J series car before 04 with acura and 05 with honda will have trans problems
the 03-04 hondas as OK but not as good as the newer ones
Old Feb 2, 2008 | 02:11 PM
blinx9900's Avatar
its an issue for sure, im on 140k same stock tranny on my 01 cls but is starting to sliip, hell its been slipping, but i wont replace it till it goes! i notice if i shift it in manual mode and let off between shifts it works perfect
Old Feb 2, 2008 | 05:33 PM
crxcess's Avatar
Default Re: do the tl/cl have trans problems? (blinx9900)
i went to acurazine and found this 57 page thread on this issue. thanks for the lead. I know now that if I get one, to get a manual trans. thanks!
http://tl.acurazine.com/forums...06818
Old Feb 2, 2008 | 08:12 PM
hilltopgraphics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxcess &raquo;</TD></TR><TR><TD CLASS="quote">i went to acurazine and found this 57 page thread on this issue. thanks for the lead. I know now that if I get one, to get a manual trans. thanks!
http://tl.acurazine.com/forums...06818</TD></TR></TABLE>
The OEM V6 trans from 2000-2003 had 3 major design issues: 1) 3rd clutch abnormal heat damage 2) 2nd gear abnormal heat damage 3) Differential taper bearings premature disentegration.
All these issues have been effectively countermeasured in the current remanufactured transmissions approved by American Honda. These trannys will have "RMH", "RMS" or "RMK" on the serial# label.
In the case of TL & CL, part of the 3rd clutch countermeasure was to also install a countermeasure ECU. The new ECU delivers a noticeable shift lag from 2nd to 3rd gear, and it hits 3rd gear with more firmness. This is to prevent 3rd clutch from slipping, but customers mistake it for another tranny problem.
In response to this issue, there is yet another countermeasure ECU which should be available in the next few weeks. It was designed to retard the engine timing during the 2nd to 3rd gear interchange, thus eliminating the feeling of a tranny malfunction.
More recent countermeasures are being put in place at Honda's certified remanufacturing facilities as we speak. As long as you get a certified Honda replacement trans, you should be ok.
Old Feb 2, 2008 | 11:24 PM
dnote's Avatar
the only cars i have had have been maual so will shifting like this all the time help save the tranny
Old Feb 2, 2008 | 11:36 PM
blinx9900's Avatar
Default Re: do the tl/cl have trans problems? (dnote)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnote &raquo;</TD></TR><TR><TD CLASS="quote">
im not sure, but it feels smoother. please try adding punctuation next time it was hard to tell you were asking a question
Old Feb 3, 2008 | 02:36 AM
Default Re: do the tl/cl have trans problems? (hilltopgraphics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hilltopgraphics &raquo;</TD></TR><TR><TD CLASS="quote">
More recent countermeasures are being put in place at Honda's certified remanufacturing facilities as we speak. As long as you get a certified Honda replacement trans, you should be ok.</TD></TR></TABLE>
lol
my trans is about toast how do I know?
1/2 pause between 2 and 3 on very fist shift when cold (even if I left the car run for a few before I drive off.
delay when getting on the trottle when getting into the pedal to merge........
Intermittent harsh reverse engagement
Old Feb 3, 2008 | 01:38 PM
Default Re: do the tl/cl have trans problems? (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">
lol
Intermittent harsh reverse engagement</TD></TR></TABLE>
I would suggest smelling your ATF. If there's a slight burn odor when cold, then there's obviously a problem. The '02 CL-S has an extended warranty, so take it in and have it checked out.
Old Feb 9, 2008 | 04:06 PM
nycjsw's Avatar
I had my transmission replaced in my 2001 Acura CL Type-S in November 2004 and again in March of 2005 (45K miles). I now have 102K miles. Should I be worried about my transmission. Can I have the dealer check it to see if it had those modifications you mentioned above? I read somewhere that if you had it replaced before March of 2005 the transmission would have the same problems as the original. Any input?
Old Feb 10, 2008 | 05:24 AM
I would suggest smelling your ATF. If there's a slight burn odor when cold, then there's obviously a problem. The '02 CL-S has an extended warranty, so take it in and have it checked out.</TD></TR></TABLE>
I changed the fluid at 41K 457k and 55K I have been in 4X and I am just gonna wait till it croaks........
Old Feb 10, 2008 | 05:25 AM
Default Re: do the tl/cl have trans problems? (nycjsw)
the newer unit should be fine since they zapped the car's performance
ppd105
Honda Civic (2006 - 2015)
Aug 5, 2013 06:13 PM
ferio252
Oct 28, 2007 04:40 PM
Integra21
Acura TL, RL & ZDX
Feb 15, 2007 07:03 AM
apeckz
Nov 29, 2005 09:06 PM
