FS: my life
Old Jul 2, 2002 | 12:42 PM
phase's Avatar
From: HELP i am under your moms bed,, and you dad just got home
Default FS: my life
OK lets start from the top
head 1999 Honda civic si b16a2
port work portflow head work
crower cams 63413
dynamic cam gears
ferrea valve train (stainless valves, ti springs, ti retainers)
skunk2 manifold port matched to the head (by portflow)
t/b is 1999 b16a bored by jg
rc 310 injectors
str polished fuel rail
sard fuel pressure regulator
bottom end
1998 ls bottom end
golden eagle sleeves bored to 84.5 mm
wisco 84.5 12:5.1 endyn pistons (bought direct so they are not bootleg)
eagle rods also endyn
all balancing was taken care of by golden eagle. the rods, crank, block line bore, al bearings and gaskets. also has there prototype oil pump 100psi.
z10 Eng. block griddle
moroso oil pan and pick up
oil pump and water pump are new as well
Misc.
jdm itr header with test pipe, paxton fuel filter. THERE MIGHT BE MORE I WILL MODIFY
JIMEL
EVERYTHING IS DISASSEMBLED, SO YOU WILL KNOW YOU ARE GETTING A FRESH SET UP.
MAKE A OFFER ON THE WHOLE LOT. HOW ABOUT $4800.00
<U>I MIGHT PART OUT IF THE OFFERIS GOOD</U>
GOD LOVES YOU, unless your an atheist then what do you care?
[Modified by phase, 10:01 PM 7/2/2002]
[Modified by phase, 6:50 AM 7/3/2002]
Old Jul 2, 2002 | 05:48 PM
phase's Avatar
Default Re: FS: my life (phase)
bump
Old Jul 2, 2002 | 08:53 PM
phase's Avatar
can i get a bump, bump
Old Jul 2, 2002 | 09:35 PM
haloseven's Avatar
darn, i thought this was a new life, i needed something to mess with in my spare time
Old Jul 2, 2002 | 09:46 PM
phase's Avatar
Default Re: FS: my life (haloseven)
no just what i have to show for the last year.
Old Jul 2, 2002 | 09:57 PM
Dorikamu's Avatar
where are you located? I will be interested in the head if you will part out
Old Jul 2, 2002 | 10:00 PM
phase's Avatar
Default Re: FS: my life (chusai)
i am located in palm springs ca.
Old Jul 3, 2002 | 01:57 AM
aNaRcHyiNmYeK's Avatar
pumps an a bump i like them girlz with a pumps an a bump
nice list of treats :thumbup
i can vouch for jimel
good guy
[Modified by aNaRcHyiNmYeK, 11:05 AM 7/3/2002]
Old Jul 3, 2002 | 02:29 PM
phase's Avatar
Default Re: FS: my life (aNaRcHyiNmYeK)
face down azz up thats the way we like to bump
o.g.- too live crew
Old Jul 3, 2002 | 04:58 PM
phase's Avatar
Old Jul 3, 2002 | 05:22 PM
SamuraiJack's Avatar
check im
Old Jul 5, 2002 | 09:44 AM
phase's Avatar
Default Re: FS: my life (SamuraiJack)
Old Jul 5, 2002 | 09:56 AM
99SilverEx's Avatar
Sounds like a great setup man.
Old Jul 5, 2002 | 10:58 PM
phase's Avatar
Default Re: FS: my life (99SilverEx)
thanks
Old Jul 5, 2002 | 11:08 PM
The Rob's Avatar
Damn, thoiught it really was a life. I need one kinda as a "daily driver" so that I don't put too many miles on mine.
Old Jul 5, 2002 | 11:47 PM
Suprdave's Avatar
Im interested, IF and WHEN you part the motor out...
Suprdave
Old Jul 6, 2002 | 12:05 AM
phase's Avatar
Default Re: FS: my life (Suprdave)
what is it that has sparked your intrest?
Old Jul 6, 2002 | 05:02 PM
forcfedcivic's Avatar
sweet motor...good luck...free bump...."k" ha ha
Old Jul 6, 2002 | 05:22 PM
phase's Avatar
Default Re: FS: my life (forcfedcivic)
thanks for props and the bump may be sum day i give you a bump" "
Old Jul 7, 2002 | 08:51 PM
garagespecial
Guest
Posts: n/a
great guy....extremely legit
Old Jul 7, 2002 | 08:56 PM
Pinhead's Avatar
New User
Default Re: FS: my life (garagespecial)
SOLD to me.....
Konigrx91
51
Dec 10, 2008 10:08 PM
vietelement
Texas -OK -LA (Sales)
Jan 25, 2008 09:07 AM
JLHDOHC
May 15, 2006 01:37 PM
fernancivic
Jan 21, 2005 04:30 PM
