Hub Removal Tool
Old Jan 29, 2008 | 08:49 PM
SikAuto's Avatar
Default Hub Removal Tool
Got a 94 accord lx want to do front rotors but need hub tool. I found one on Tas Performance for $60 but dont know if it would help me much. Can anyone let me know if youve used one or even if its worth me buying thanx.
Old Jan 30, 2008 | 04:19 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Hub Removal Tool (SikAuto)
I haven't seen that tool before so I went and looked... looks like it's supposed to slide through the assembly from where the axle goes into the hub and then screw the nut on like the axle nut. This probably allows you to attach a slide hammer to it or allows you to hammer it through from behind.
I wouldn't say you need it. If that assembly doesn't want to come out after some hits of a hammer on the back of the rotor it's probably not coming out without use of a press. I would save my money and spend it on something else.
If the assembly doesn't come out, remove the knuckle from the car and take it to a machine shop to have them pressed out, probably cost 25-50. Upon install, clean the bearing and knuckle of all rust and grease them up to help prevent rusting like this again.
Old Jan 30, 2008 | 04:55 PM
mattygee5000's Avatar
1.Remove steering knuckle from car
2. Get some long sacrificial bolts (m12X1.5 I -think-) Remove bearing retaining bolts and install long bolts.
3. With knuckle in shop vise, use air hammer to pound on ends of bolts to work bearing out of knuckle.
4. Rotors can then be removed/reinstalled.
5. use original bolts to pull bearing back into knuckle
Do not attempt to use a slide hammer or other means to pull bearing out of knuckle by pulling on wheel lugs. You will damage the bearing. There is a rather expensive tool that supposedly gently separates the inner race from the outer race allowing you to reassemble the bearing but I have my doubts it is harmless to the bearing.
MG
97 accord SE family hauler
imadigitalgod
Jun 9, 2010 01:54 PM
m1northreat
Honda S2000
Feb 24, 2008 11:35 AM
Atheist
Jun 7, 2006 04:03 AM
truesleeper
Apr 14, 2005 10:58 AM
JohnnyEF
May 1, 2002 06:27 PM
