Walbro 255 fuel pump question.....
Old Jan 29, 2008 | 08:14 PM
vtec_killer_'s Avatar
Default Walbro 255 fuel pump question.....
Bought a walbro fuel pump from a friend and he didnt give me the connector which has the two or three wire with the clip on it.. Is it ok to use a type butt connector in the fuel tank? any advice... here is a photo of what i am talking about..
Old Jan 30, 2008 | 12:28 AM
Legion's Avatar
* B A N N E D *
Default Re: Walbro 255 fuel pump question..... (vtec_killer_)
What car is it for? If it's a 92-00 Civic or a 94-01 Teg, then you don't need to mess with the wiring. It's plug and play.
But if it's for something else and you need to re-wire it, I would avoid butt-connections since they suck. Soldering is always recommended. Just don't blow yourself up.
Old Jan 30, 2008 | 01:11 PM
97grnrs's Avatar
i used two shielded ( plastic cover) slide on connectors and it works fine. i just gently pinched them so they stay tight and wont come off easily. i used the shielded ones so they wont touch each other and spark ..
Old Jan 30, 2008 | 04:43 PM
Default Re: Walbro 255 fuel pump question..... (Legion)
95 civic coupe ... so u guys think that those female couplers that slide on should work?
Splock
Jul 30, 2017 08:57 AM
thunderboy
Jun 20, 2011 03:52 PM
maddcrx
May 9, 2008 07:29 PM
T817
Mar 15, 2002 05:50 PM
