Honda S2000 Honda S2000
what size nut is it for the rear struts?
Old Jan 29, 2008 | 08:13 PM
f22b-dohc's Avatar
Default what size nut is it for the rear struts?
i cant search for ****
number 17 is the bolt....
i just wanted to get a head start...installing coilovers and noticed idont have the nuts and the stock ones are welded on
what size/pitch (?)do i need?
trial and error works too, but im thinking somone will know
Old Jan 30, 2008 | 10:31 AM
- BSeRiouS -'s Avatar
Default Re: what size nut is it for the rear struts? (f22b-dohc)
17mm or 19mm? Hmmm.
17mm
Old Jan 30, 2008 | 10:33 AM
Default Re: what size nut is it for the rear struts? (- BSeRiouS -)
wait. You asking about the nut. Go to a honda dealership and ask for the rear strut bolt from a majority of any honda. They all should work
Old Jan 30, 2008 | 02:18 PM
ap1FTW's Avatar
if you don't want to hassle with finding a new one and you have an impact gun just use that and it should take it right off i've done this on a couple different cars and its worked fine the nut breaks off cleanly too
Old Jan 30, 2008 | 02:59 PM
f22b-dohc's Avatar
Default Re: (ap1FTW)
^interesting, i have a few honda struts lying around
thanks meng
Old Jan 30, 2008 | 03:01 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (f22b-dohc)
Hmm, the stock ones should NOT be welded on. There is a "nut" looking piece on the other end of the "fork" that's spot welded on, but that stays put. Take a look at the other side of the "fork" and that's the bolt that you remove. It's a 17mm.
Old Jan 30, 2008 | 03:20 PM
ap1FTW's Avatar
Default Re: (shamoo)
^he's looking for the nut that that bolt goes into i'm assuming he's installing coilovers and they do not come include this nut so you need to either remove the stock nut or find a new one
Old Jan 30, 2008 | 05:48 PM
usually, but don't quote me, higher end (flag ship) coil overs come with a spot weld locking nut onto the shock body just like OEM strut and shock. My BuddyClub RSD's came w/ these nuts spot welded already, but the BuddyClub N+Specs, you had to get buy a seperate nut for the lower shock bolt at each end. JIC FLTA2's also came with spot weld lock nuts onto the shock body, but the JIC FLTA1's you had to buy the shock nuts for on the rears.
Just go to the dealership, they always have these in stock. and there cheap.
Old Jan 30, 2008 | 06:46 PM
f22b-dohc's Avatar
Default Re: (- BSeRiouS -)
ap1ftw is right... his info is what i needed.
i got my tein ra used and since they are not higher end, it doesnt have a nut on them....
trecool44
May 22, 2009 09:42 AM
raffaelli
Jan 11, 2009 07:01 AM
msinsky14
Aug 18, 2007 01:06 PM
aZnjCC
Aug 25, 2004 11:55 AM
leprechan117
Mar 7, 2003 01:21 PM
