Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
should i buy this tl
Old Jan 29, 2008 | 07:16 PM
dnote's Avatar
Default should i buy this tl
for sale:2003 acura tl type-s 55k has the tranny warranty asking 16,9K
could i find better?
Old Jan 29, 2008 | 08:11 PM
YeuEmMaiMai's Avatar
Default Re: should i buy this tl (dnote)
too much
should be able to get the car for $15K. also run the vin past the acura dealer to make SURE that the car has trans warranty as only SOME of the 03 cars are covered.
Old Jan 30, 2008 | 05:30 AM
pnthr30's Avatar
Default Re: should i buy this tl (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">too much
should be able to get the car for $15K. also run the vin past the acura dealer to make SURE that the car has trans warranty as only SOME of the 03 cars are covered.</TD></TR></TABLE>
I agree 100%.....I would even argue that if you look long enough, you should find one for a ways less than $15K........Good luck on your hunt.
Old Feb 2, 2008 | 09:51 PM
dnote's Avatar
Default Re: should i buy this tl (pnthr30)
what about a 03 type s with 67k for 13,9 covered by tran warranty
Old Feb 5, 2008 | 08:54 PM
DownShiftPerformDC2's Avatar
The 03 for $13.9 sounds alot better with the warranty . . . I personally found a 03 Type s with 75k trans warranty and all for 11k
Old Feb 7, 2008 | 08:13 PM
dnote's Avatar
Default Re: (DownShiftPerformDC2)
so i went and test drive the tl(for 13.9k) and after i put it in drive and rolled say 10ft, i pressed on the brake firmly. During which there was a loud grinding noise on the passenger side front wheel. Any i deads what this, also the outsides of all four tire treads are worn low?
Old Feb 9, 2008 | 09:50 PM
BamBamDB1's Avatar
Default Re: (dnote)
Brakes need to be replaced so it sounds.
BTW, I bought my 2003 TL-S with 70K miles for 17K from a dealer. It has Navi though. It had the warranty up to 109K miles... It's at 116K now.
Old Feb 12, 2008 | 02:25 PM
Default Re: (dnote)
tell him 13.4 and replace both front rotors and calipers
Old Feb 14, 2008 | 06:53 AM
pnthr30's Avatar
Default Re: (YeuEmMaiMai)
Best case, the car was sitting for a while and the calipers and rotors need to "roll" some rust off. Worst case, the rotors and calipers need to be replaced - this is not a big deal, and something that you can do yourself if need be.
As another point of reference, I got an 03 TLS for $11K - 97,000 miles. All service work was done at the Acura dealer, and interior and exterior were in very good condition. Not a smokin deal, but not bad - I needed a car and was willing to pay a tad more; didn't have the time to scour for the perfect deal.
Old Feb 14, 2008 | 09:47 AM
TL Type S's Avatar
My friend picked one up with 43k for $9,000. Search around. Definitely don't get one that hasnt had the tranny swapped out. Mine is in the shop right now and they want $3700 for the tranny plus labor. I have 140k on mine and they only warranty up to 100k.
Old Feb 14, 2008 | 09:48 AM
TL Type S's Avatar
Default Re: (BamBamDB1)
The worn outside tires are because the guy corners hard and has rotated the fronts to the back after they wore down.
THE GAME IS THICK
Acura TL, RL & ZDX
Nov 8, 2009 10:08 PM
Desiss
Acura TL, RL & ZDX
Oct 15, 2007 03:57 PM
BB2H22
Acura TL, RL & ZDX
Mar 6, 2007 01:29 PM
George Knighton
Sep 10, 2006 02:54 PM
sublimnal
Jun 15, 2003 10:27 PM
