turbo crx wont start
crx wont start its fully built everything is hooked up correctly. using fmu and stock injectors 255 fuel pump. car cranks but wont turn over i mean it tries to a couple of times but then stops after car is flooded. block has had work done to it so timing is off a tooth i have adjustable cam gear to make up for that but not sure if i need to advance or retard cam gear. all parts on motor are new even the distributor. im running out of ideas really need some help here. when the car tries to fire it goes pup pup---------pup----------pup and then the engine is flooded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr00civicsi »</TD></TR><TR><TD CLASS="quote">crx wont start its fully built everything is hooked up correctly. using fmu and stock injectors 255 fuel pump. car cranks but wont turn over i mean it tries to a couple of times but then stops after car is flooded. block has had work done to it so timing is off a tooth i have adjustable cam gear to make up for that but not sure if i need to advance or retard cam gear. all parts on motor are new even the distributor. im running out of ideas really need some help here. when the car tries to fire it goes pup pup---------pup----------pup and then the engine is flooded.
its doing that cause your timing is off.throw out the fmu and spring for a chiped ecu and a set of 450 dsm injectors.as for the cam gear i would take it to someone how knows what they are doing.
</TD></TR></TABLE>its doing that cause your timing is off.throw out the fmu and spring for a chiped ecu and a set of 450 dsm injectors.as for the cam gear i would take it to someone how knows what they are doing.
