rim and tire suggestion for b18 turbo street track car ??
Hey guys, I don't know exactly what size tire and width of rim I should use on my fully built ls turbo hatch .. I want to run 15s or 16s but how wide of a rim should I get ? Tire size? Some friends suggested a tire size of 225/40/15? Possible 245s with a rime size of 15 by 8.5 to 9 ... any suggestions ? Also aside from gettin sticky tires anything else I should get to also help add to gettin good traction ?
are you looking for a slicks setup or you looking for a street tire?
how much power are you making?
I want more of a slick option although I'm driving it on the street .. And my setup isn't finished yet but I'm certain ill be around 320 plus wheel horse
your options are:
get a 15x7 or 15x6.5 wheel, use a 23x7.5x15 MH slick. that would work ok with the hp you have.
or get a drag wheel. lets say our VPD 13x7.5 lightweight drag racing wheel and use a 23x8x13 M&H slick on that.
either tire is not for the street, track only.
Well no matter what I'm gonna run whatever tire I have on the street and the track more street tho .. And wouldn't u think that a rim 15 by 7 would be to thin .. I mean I would want something a little wider then stock .. Maybe a different offset .. Basically I'm looking for the best possible route to have good traction
youre making only 320hp, you dont need a 9" wide rim.
slick width doesnt necessarily mean you use the same rim width. lets say some 8.5" wide slick you can use 7.5-8" wide. or 7.5" wide slick, use 6-6.5" wide rim.
Each slick has its own manuf spec on what rim width to use. Even some 10" wide slicks use 8" wide rims.
