Help w/ hose location..
Old Jan 29, 2008 | 12:01 PM
Chris.B.'s Avatar
Default Help w/ hose location..
Im just finishing up my lsvtec swap, basic setup: 95 b18b1 block, 99 b16 head, itr intake manifold, b20 throttle body (throttle body is temporary), and its going into a 92 Si hatch. Im having a little trouble w/ the last few hoses. Where do these connect to..?
Thanks,
Chris
The first one is located on the upper radiator hose housing.. What does this connect to?
These two on the b20 throttle body??
Can I just plug this???
Last, Next to the bigger hose that goes from the IM to the thermostat housing is a smaller outlet. Where does this connect to..?
NO PIC...
And just throwing this one in there...
Old Jan 29, 2008 | 12:14 PM
Brick Top's Avatar
Default Re: Help w/ hose location.. (Chris.B.)
tube in the #1 pic connects to the lower tube on the throttle body in pic#2. coolant line. The upper tube on the throttle body connects to the charcoal canister. and pic #3 you can cap it. and a i dunno on question 4.
Old Jan 29, 2008 | 01:03 PM
Chris.B.'s Avatar
Default Re: Help w/ hose location.. (Brick Top)
There are two lines coming from the charcoal canister, a small and a big one.. Im not running a pcv system, I caped it off on the intake manifold, and just left the breather box open.
Old Jan 29, 2008 | 05:35 PM
Chris.B.'s Avatar
This is the other one I was talking about on the intake manifold. Where does this connect to? Is Brick Top correct about the line from the charcoal canister to the top of throttle body?
Thanks,
Chris
Old Jan 30, 2008 | 08:44 AM
Chris.B.'s Avatar
Anyone?
Old Jan 30, 2008 | 08:51 AM
sgallagher's Avatar
Isn't there a hose routing diagram on your hood? That should tell you where all youre vacuum lines go.
Old Jan 30, 2008 | 09:36 AM
Rigginit's Avatar
Default Re: Help w/ hose location.. (sgallagher)
That one i have capped off. All my lines were used and for some reason on my manifold that one was still open .... capped it and no problems for the 2-3 years ive had this engine
Old Jan 30, 2008 | 09:50 AM
Chris.B.'s Avatar
Default Re: Help w/ hose location.. (Rigginit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rigginit &raquo;</TD></TR><TR><TD CLASS="quote">That one i have capped off. All my lines were used and for some reason on my manifold that one was still open .... capped it and no problems for the 2-3 years ive had this engine
Your talking about the one under the injector right?
What about the one on top of the throttle body?
Thanks guys,
Chris
Old Jan 30, 2008 | 12:26 PM
Cpt Ben's Avatar
open one on top of TB is charcoal canister, you can just leave it open afaik.
Old Feb 1, 2008 | 03:43 PM
Brick Top's Avatar
Default Re: (Cpt Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cpt Ben &raquo;</TD></TR><TR><TD CLASS="quote">open one on top of TB is charcoal canister, you can just leave it open afaik.</TD></TR></TABLE>
93grayeg
Feb 4, 2015 03:34 PM
b18AM
Aug 1, 2010 11:16 PM
prelude_93vtec
Jun 26, 2007 06:30 AM
EF8IGHT
Nov 8, 2005 07:53 AM
wanttorace
Jul 8, 2003 08:28 PM
