2001 Acura Integra GSR W/ Drag Turbo & AC (CLEAN)
2001 Integra GSR with Drag 3 turbo kit. Black with tan leather 4-door. Never wrecked or had any paint work. Lowered 1" with Eibach springs, also has perfect alignment with a Skunk 2 Pro camber kit. (no inside edge tire ware) Newer tires with about 75% tread. 90K miles service was done at 89K with all OEM Acura parts. Mods include; 20% Window tint. Boost and EGT gauges mounted in instrument cluster bezel. Drag 3 turbo kit @ 8 PSI and never any higher, OBD1 ECU, 255 LPH fuel pump, Fuel pressure regulator, 70 mm throttle body, RC 550 cc injectors, Skunk 2, 2-1/2" exhaust, Custom 3" down pipe, steel braided oil and fuel lines with AN fittings. Type R valve cover with carbon fiber spark plug cover. Tial 35mm wastegate that re-circulates back into the exhaust. ( this car is 100% SMOG LEGEL with a highflow cat- converter) and working A/C. HKS blow off valve, Drag FMIC, large K/N air filter. The car is also equipped with a Low Jack GPS tracking alarm system. All work on this car was done right, absolutely No hacking) It is fully tuned and has ran perfectly for about 3 years with absolutely no problems. It has never been to the track and only Dyno 'd twice. It puts down 245 WHP and 185 lb. ft. tq. The Dyno graph is available. Please feel free to call me if you have any questions. I also have all of the stock parts that will be included with the car. Let me know if you would like to see more pictures. $10700 Dusten 541-337-0172
Modified by SHORACETEAM at 10:13 AM 2/4/2008
Modified by SHORACETEAM at 5:50 PM 3/13/2008
Modified by SHORACETEAM at 12:49 PM 3/27/2008
SHORACETEAM
Mar 13, 2008 06:51 PM
GSR4D
Sep 23, 2005 10:11 PM
