Suspension & Brakes Theory, alignment, spring rates....
Problems with rear suspension
Old Jan 29, 2008 | 09:55 AM
kbbluepits's Avatar
Default Problems with rear suspension
I've got an EK hatch and the passenger rear wheel is crazy loud!! I thought it was the threads on the tires going bad (which they were) so I changed the tires. Now it's louder!! The noise is noticeable around 35mph and up. It sounds like a low grinding sound. I've checked to see if it's grinding against anything but I've got alot of clearance and know for sure it's not scratching anything.
One thing I did notice was when I drive on the hwy and the road curves to the right....the noise stops. When I go straight it's loud. When the road curves left...very loud. When the road curves right...noise is gone and car is silent!
What is wrong with the car? Is it the camber/toe? Is it the wheel bearings gone bad?
Any help would be much appreciated.
Old Jan 29, 2008 | 05:51 PM
Targa250R's Avatar
be professional
Default Re: Problems with rear suspension (kbbluepits)
Provided that you don't have any brake components rubbing back there, you probably have a bad wheel bearing.
mikehinkle
Feb 20, 2014 11:39 AM
rob_typeR
Jul 27, 2012 10:29 AM
FlewByU352
Suspension & Brakes
11
Feb 2, 2011 08:36 PM
xpdude
Aug 6, 2009 03:11 PM
whagkangmakulet
Jul 14, 2004 05:06 PM
