itr sway bar -> EH
Old Jan 29, 2008 | 09:33 AM
obuhmyuh's Avatar
Default itr sway bar -> EH
lookin to put an itr sway bar on my 95 del sol si, what fabrication, if any is needed? ive looked for write ups using search and faq but have found nothing. and from what i've heard its not just a straight "bolt-on".
thanks
Old Jan 29, 2008 | 09:34 AM
BlueIntegraBoy's Avatar
Default Re: itr sway bar -> EH (d[sick]sTeena)
Look up ASR brace
http://www.asr-parts.com
Old Jan 29, 2008 | 09:39 AM
obuhmyuh's Avatar
Default Re: itr sway bar -> EH (BlueIntegraBoy)
that website doesn't really answer my question, and im going to go with a beaks subframe reinforcement... the only write-up that i've found doesn't show any fabrication. but from what ive heard from friends or other h-ter is that theres some holes that need to be drilled???
Old Jan 29, 2008 | 10:24 AM
.PLUMMM's Avatar
I'm not sure if its a direct bolt on application, but I would assume so. You will find threads of subframe tearout with larger swaybars using the Beaks kit. None so far for ASR and I love my ITR/ASR combo. You really should look into it. Good luck!
Modified by .PLUMMM at 2:42 PM 1/29/2008
Old Jan 29, 2008 | 10:44 AM
obuhmyuh's Avatar
Default Re: (.PLUMMM)
what do you mean by subframe tearout?
Old Jan 29, 2008 | 10:47 AM
obuhmyuh's Avatar
Default Re: (d[sick]sTeena)
nevermind i did some research on tearout, that sounds pretty shitty. but will i experience subframe tearout with a beaks subframe brace and neuspeed tie bar braces?
Old Jan 29, 2008 | 01:39 PM
.PLUMMM's Avatar
I am not saying you will. There are plenty of people who use the Beaks kit and are fine. It would probably behoove you to spend less money on one piece of bracing rather than buy a Beaks kit and Neuspeed braces. With this being said, the Beaks kit would probably be fine for daily driving, but if the car will be under any hard cornering and/or tracked often, you might want to look into the ASR brace. There hasen't been one bad review ive seen, and they look great. Just a little extra food for thought...
Old Jan 29, 2008 | 01:41 PM
DC2Projektz's Avatar
Im not completely sure but if the del sol is just like an eg, than it should be a direct bolt on except for the fact that the holes arent threaded for the brace so you have to add 4 nuts and bolts through the sub frame
Old Jan 29, 2008 | 01:43 PM
.PLUMMM's Avatar
I have a 94 civic sedan and mine bolted in directly...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d[sick &raquo;</TD></TR><TR><TD CLASS="quote">sTeena]nevermind i did some research on tearout, that sounds pretty shitty. but will i experience subframe tearout with a beaks subframe brace and neuspeed tie bar braces?</TD></TR></TABLE>
There's a possibility. I've heard tearouts more with the "EK" chassis than the "EG" chassis, which your Sol is based on. IMO, I would go with the ASR brace for a better piece of mind.
https://honda-tech.com/zerothread?id=1564967
Old Jan 29, 2008 | 07:46 PM
obuhmyuh's Avatar
Default Re: (BlueIntegraBoy)
thanks everybody for your input, the only reason im set on beaks is because its part of a kit im buying off a buddy which includes the beaks subframe brace, neuspeed tie braces, the sway bar and all hardware. but asr is something i will definately look into upgrading to. and <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2Projektz &raquo;</TD></TR><TR><TD CLASS="quote">Im not completely sure but if the del sol is just like an eg, </TD></TR></TABLE> yes it is i just call it an EH because i dont live in Japan haha. so are you saying that i have to drill 4 holes?
Old Jan 29, 2008 | 08:33 PM
no you dont have to drill 4 holes, there are already 4 holes but they arent threaded so you cant just add bolts. You have to put bolts through the subframe, add the brace and bolt it down with some lock nuts. hope this helps.
EG6_SiRII
14
Dec 7, 2003 06:44 PM
DeDonDeRosa
Mar 3, 2003 12:26 PM
Grocery Getter
Aug 2, 2002 07:24 AM
RS_POWER
Jun 5, 2002 06:09 AM
01geeser
May 9, 2002 05:04 AM
