"Unusual" eratic idle - accord
Ok before Everyone jumps in and says the obvious, I already tried them...
I already
- Cleaned Throttle body
- Replaced IACV
- Replaced Fit Valve
- Changed map sensor
What else would cause the annoying honda Idle?
It idles at 1000 then jumps to 1800...
Back and forth non stop, not just when its cold.
95 accord
4cyl EX vtech
manual
Any ideas?
I was thinking maybe the TPS or the ECU??
I already
- Replaced IACV
95 accord
4cyl EX vtech
manual
Any ideas?
Vacuum leak = Check all your vacuum lines and IM & TB gaskets for cracks?
And
P2 connector = Ensure that the MAP and TPS connectors are connected to the proper sensor. You may have swapped them and it will not throw a DTCode.
And
I Like Hondas
Jun 11, 2006 05:35 PM
