Need HELP!!!
Old Jan 29, 2008 | 06:32 AM
Dizayne's Avatar
Default Need HELP!!!
What could make my 97 Honda Civic Ex hesitate at low RPMs?? Or when i let off the gas it hesitates.... at first it done it about once a month and i would turn the car off for like 10 seconds and it would stop doing it.....Now it does this constantly....i replaced the fuel filter today but that wasnt it.....it does this real bad in first and second gear like it isnt getting enough fuel to it or something....could this be the plug wires>???? or what i also put all new plugs in it today....NEED HELP>.....thank you....I really cant fully explain how it acts in words....
Old Jan 29, 2008 | 06:50 AM
Dizayne's Avatar
Default Re: Need HELP!!! (Dizayne)
Anyone With Some Advice??
Old Jan 29, 2008 | 05:15 PM
Dizayne's Avatar
Anyone????
Old Jan 29, 2008 | 05:20 PM
z6hatchboy's Avatar
You could try the small thing like the plugs, but im thinking the o2 sensor. Is it sputtering?
Old Jan 29, 2008 | 09:05 PM
Dizayne's Avatar
Default Re: Need HELP!!! (z6hatchboy)
Yea Like its not getting enough gas to it but it does it the worse in first and second gears at low rpm's.....
Old Jan 30, 2008 | 10:20 AM
Dizayne's Avatar
bump
Old Jan 30, 2008 | 11:12 AM
Dizayne's Avatar
bump bump bump it up
Old Jan 30, 2008 | 12:35 PM
Dizayne's Avatar
bump
Old Jan 30, 2008 | 01:55 PM
kilroy79's Avatar
worst case scenario , the gears have worn down and are slipping, happened in my 00 EX
Old Jan 30, 2008 | 02:28 PM
jasony0630's Avatar
76.26.106.124
check your iacv, it happened on my car.
are you getting any cel's?
Old Jan 30, 2008 | 09:05 PM
Dizayne's Avatar
What is iacv???
and cel's??
Old Jan 30, 2008 | 09:59 PM
jasony0630's Avatar
76.26.106.124
idle air control valve = iacv
if it is automatic it will be under your throttle body, if it is a 5 speed it is the cylendrical looking thing right behind your intake manifold.
check engine light = cel
now for this part, i really hope you already know.
Old Jan 31, 2008 | 06:45 AM
Dizayne's Avatar
Default Re: (jasony0630)
Ok yea it is a 5 speed....and the check engine light is on has been on since i got the car but i have a exhaust system on it and aftermarket headers so i figured that was causing the check engine light to be on....if it is the idle control air valve how much does them normally cost to repair??
Old Jan 31, 2008 | 06:54 AM
slo_hatch's Avatar
Default Re: (Dizayne)
changing the exhaust wont make the cel come on unless they left an o2 sensor off. take it to autozone or advance and have them check to see what the cel codes are for.
Old Jan 31, 2008 | 05:58 PM
Dizayne's Avatar
Default Re: (slo_hatch)
bump
Old Jan 31, 2008 | 10:00 PM
Dizayne's Avatar
bump
CRIMDC2
Jan 3, 2011 01:42 AM
project90da
Jul 12, 2010 05:17 PM
yayizzil
Apr 5, 2009 03:51 PM
CRX_CRAZY07
Apr 2, 2007 06:26 PM
A.E Motoring
May 16, 2005 05:55 PM
