D16Z6 Si tranny in EF
I'm currently using my D15 tranny, but want to install the D16Z6 si tranny for the lower gear ratio and newer gears. I know I will need the new Hasport tranny mount, but what about the axles and shift linkage? Can I use the originals?
Thanks,
Matt
Thanks,
Matt
u can use the stock linkages and also from what i have heard even drive shafts from the 91 but change them if there not in good shape also u will need the rear tranny mount bracket and the innovative hydro conversion kit not the mecanical one the real hydro one its good only thing u got to find out that im still looking on is the side tranny mount on the passenger fender wall i can figure out if i need a 91 stock mount or a 92 mount off a hydro of ur going for a crazy race clutch and press plate go hydro saves u the time of replaceing clutch cables and from snaping or streaching under stress also if u got a weak leg like me u will need the hydro to make ur life easy lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onesikgsr »</TD></TR><TR><TD CLASS="quote">I'm currently using my D15 tranny, but want to install the D16Z6 si tranny for the lower gear ratio and newer gears. I know I will need the new Hasport tranny mount, but what about the axles and shift linkage? Can I use the originals?
Thanks,
Matt</TD></TR></TABLE>
You'll use your current axles and shift linkage, but you're going to have to install a complete hydraulic clutch system.
As mentioned above, you should really be looking for an '88-91 Si trans with a cable actuated clutch. It bolts right in; no need to change mounts or clutch setup.
Thanks,
itrpwrdrex
Jul 28, 2007 08:33 PM
