How long do tungstens usually last?
Old Jan 28, 2008 | 11:46 PM
xxbulaxx's Avatar
Default How long do tungstens usually last?
Just wondering...Assuming your proficient at welding, how long does a tungsten rod typically last?
Old Jan 28, 2008 | 11:52 PM
dave@passenger's Avatar
Default Re: How long do tungstens usually last? (xxbulaxx)
I go through a 1/16 tungsten every 2-3 months (well technically two, one zirconiated and one thoriated), the 3/32 a little longer.
Old Jan 28, 2008 | 11:57 PM
xxbulaxx's Avatar
Default Re: How long do tungstens usually last? (dave@passenger)
Oh ok, longer than I expected. I'm just starting to get into it, and I see a pack of 10 rods on cyber weld for say $35(3/32 2% thoriated)...I was hoping they weren't something you go through constantly.
Old Jan 29, 2008 | 02:03 AM
ROTARY's Avatar
i use 3/32" and and a single piece will last me about 5 months.... but i don't weld everyday like Dave.
Old Jan 29, 2008 | 02:08 AM
Goullish's Avatar
Yeah, they aren't an expensive consumable. I've been through maybe one pack of 3/32 in the last 2 years, welding around an hour a day.
Old Jan 29, 2008 | 07:08 AM
DESTROYER's Avatar
Isn't it true that over time you blow all the non-tungsten particles out of the tip, thus decreasing it's re-starting capabilities? It was a topic I read a while ago in reference to robotic welding.
Old Jan 29, 2008 | 07:44 AM
david@didrace.com's Avatar
Default Re: (DESTROYER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DESTROYER &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it true that over time you blow all the non-tungsten particles out of the tip, thus decreasing it's re-starting capabilities? It was a topic I read a while ago in reference to robotic welding.</TD></TR></TABLE>
Typically you're resharpening the point every so often when manually welding because **** happens. Robotic welding would be a different story though.
Old Jan 29, 2008 | 08:00 AM
Yeah that is true, what I do to help eliminate that is sharpen the tungsten to a fine point, than knock the tip off. It doesn't eliminate the problem, but it does in fact help.
Old Jan 29, 2008 | 12:47 PM
JDMs1eeper's Avatar
Default Re: (dave@passenger)
they last a long time. No worries
Old Jan 29, 2008 | 02:49 PM
DESTROYER's Avatar
My tungstens typically last a few months anyways. I still have all the t's I bought 3-4 years ago
albertleee
Oct 18, 2007 08:37 PM
RACEPAK
Welding / Fabrication
12
Dec 5, 2006 06:00 PM
LSEGHATCH
18
Nov 24, 2005 05:49 PM
silver_nteg
Jul 29, 2004 01:47 PM
