Will a P07 ECU(VTEC) work instead of a P06 ECU(non-vtec)?
Old Jan 28, 2008 | 10:22 PM
612tunerh22's Avatar
Default Will a P07 ECU(VTEC) work instead of a P06 ECU(non-vtec)?
I have a 1992 Civic lx that needs an ECU. It is sappose to have a P06 (non-vtec) ECU but I have a P07 (vtec) ECU and I am wondering if it will work the same?
Old Jan 28, 2008 | 11:09 PM
StorminMatt's Avatar
Default Re: Will a P07 ECU(VTEC) work instead of a P06 ECU(non-vtec)? (612tunerh22)
It won't work right. Not only are the fuel maps wrong. But the P07 is also going to look for a VTEC pressure switch, VTEC solenoid, five wire oxygen sensor, and EGR valve.
Old Jan 29, 2008 | 06:33 AM
Default Re: Will a P07 ECU(VTEC) work instead of a P06 ECU(non-vtec)? (StorminMatt)
so it will run but it won't run the way it is suppose to?
Old May 30, 2008 | 01:10 PM
Frugal Fool's Avatar
if you are looking for a P06, I saw one at a local yard. If you are interested in trading for a P07-A##, let me know and I would go pick it up.
Old May 30, 2008 | 01:22 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 612tunerh22 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1992 Civic lx that needs an ECU. It is sappose to have a P06 (non-vtec) ECU but I have a P07 (vtec) ECU and I am wondering if it will work the same?</TD></TR></TABLE>
it should start the car, but it will not run well.
It will also have several CELs.
Old May 30, 2008 | 01:23 PM
blk92_d16's Avatar
Default Re: Will a P07 ECU(VTEC) work instead of a P06 ECU(non-vtec)? (Relic1)
beefjerky
Oct 22, 2007 10:34 AM
pnoipj89
Jan 9, 2007 07:47 PM
wzachmorris69
Nov 8, 2006 10:02 AM
Bartman201
Oct 3, 2005 01:49 AM
98civic4dr
Oct 20, 2004 01:09 PM
