Engine cannot rev pass 4000 rpms?
Old Jan 28, 2008 | 08:18 PM
Damon Reeves's Avatar
Default Engine cannot rev pass 4000 rpms?
Hey guys..
I have a 1994 Acura Integra Gsr....Can't seem to figure out the problem.
The car starts/idles normal....but cannot rev pass 4000 rpms.
Makes a disctinct gagging noise...so it doesn't reach to 4000 rpms smoothly..more like lagging power.
What can be wrong?
Old Jan 29, 2008 | 06:21 AM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: Engine cannot rev pass 4000 rpms? (Damon Reeves)
dizzy
Old Jan 29, 2008 | 09:42 AM
Crazydave's Avatar
Default Re: Engine cannot rev pass 4000 rpms? (NHswaps13203)
any codes?
Are you sure the car is not in a limp home mode?
Old Jan 29, 2008 | 01:11 PM
Default Re: Engine cannot rev pass 4000 rpms? (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">any codes?
Are you sure the car is not in a limp home mode?</TD></TR></TABLE>
No CEL.
Not so certain how to check if the vehicle is in limp mode other than when the CEL turns on and the engine cannot rev pass 6500 or so.
Tried checking for any Codes and no CEL flashes.
Old Jan 29, 2008 | 03:23 PM
Crazydave's Avatar
What changes have you done to the engine/fuel/etc?
Have you checked the ignition timing?
Do you have adjustable cam gears?
Old Jan 29, 2008 | 06:28 PM
SDP190416's Avatar
did you mess with your TPS & MAP sensors? If you did, swith the tps & map sensor plug because i had the same problem, when you start it, it idles good but wont pass 4k when WOT. i dont know if itll fix your problem but just try it out.
steveteggy92
Jun 21, 2011 11:49 AM
meric
Honda Civic (2001 - 2005)
Apr 16, 2008 09:41 PM
itr1244
Jun 26, 2006 08:14 AM
Quade
Nov 24, 2005 12:15 PM
polymath
Dec 9, 2003 01:11 PM
