help mpfi fuel Consumption 14mpg :(
Old Jan 28, 2008 | 07:09 PM
mario_pic's Avatar
Default help mpfi fuel Consumption 14mpg :(
i did a mpfi swap to my 91 civic dx auto and i dident test how the fuel Consumption was i did it on one tank and i got 14mpg out of it i was like wtf i got it etested and it passed and had a o2 replaced can it be posible that a code 20 eld can be causeing the problem also i hade the cluster changed with a 91 civic ex cluster auto can that also cause problems also at start with a cold motor it idels at 1900 and drops to 1500 a bout 20 sec after start after it warms up its idels at 800 900 can there be a problem with my conections or my vac lines to cause thiss horable Consumption also noticed that 3 gear feels like its to low to pick up but once it shifts down to 2 and then 3 its oke can it be a tranny problem also how dose the tranny know how to shift and will a ps9 ecu cause thiss problem
Old Jan 28, 2008 | 07:17 PM
mario_pic's Avatar
Default Re: help mpfi fuel Consumption 14mpg :( (mario_pic)
help lol
Old Jan 28, 2008 | 09:39 PM
mario_pic's Avatar
bump
Old Jan 28, 2008 | 10:50 PM
~sp33~'s Avatar
EFB055
Has it had a basic service? filters/sparkplugs/ etc? And code 20: Electrical load detector, I would imagine it being unrelated to fuel consumption.
Old Jan 29, 2008 | 11:25 AM
mario_pic's Avatar
Default Re: (~sp33~)
plugs where checked that where oke wires are the stock dpfi 1.5 wires and injecters im not shur if there fine or not like they where a ebay buy with my mpfi swap so it was a hit and miss id dosent seem to be miss fireing or enethying the fuel filter is the stock one ro not shur really did a oil change b4 the etested is there a way i can test my fuel injecters to see if thay are spraying right ??? or do i need to send them in
Old Jan 29, 2008 | 12:03 PM
B16CRXT's Avatar
do you smell gas? check for leaks. What ECU are you using?
Old Jan 29, 2008 | 04:51 PM
mario_pic's Avatar
Default Re: help mpfi fuel Consumption 14mpg :( (B16CRXT)
it dosent got eney leaks its runing a ps9 off a 91 civic ex auto sedan also the o2 was relcated to the cat i was wondering will that cause a problem
Modified by mario_pic at 6:02 PM 1/29/2008
Old Jan 29, 2008 | 06:32 PM
~sp33~'s Avatar
EFB055
Yeah that can cause a problem. Does it idle like crap? I would have thought it would throw a code for that sensor though
Old Jan 30, 2008 | 11:08 PM
mario_pic's Avatar
well it idles nice after warm up i also noticed my tranny shifts after 60 but to get to there it revs about 4000 just to shift at that point or elts it will stay in over drive 3 my shift points are low for first sec and 3ed 4th may be the problem but im haveing a bad feeling its bad injecters is there a way i can find out if there bad or not because i dont want to get new injecters if mine are still good i also noticed that my gas pedel is super sensitive like if i tap the gas and press a little bit more it will feel like im pressing it half way down and the car tires spin a bit its odd lol chould it be a tps problem ????
bank2me
May 10, 2013 02:10 PM
EJ1_Sleeper
Mar 7, 2008 08:10 PM
thetuna
Apr 28, 2007 09:02 AM
CalTucMol
May 12, 2006 02:59 PM
KiD Fr0m Da 516
Feb 20, 2006 09:04 PM
